Amazon Halo Teardown
Amazon Halo Teardown, Chip decapping, and PCB delayering
JPEG Image - 1.27 MB - 12/31/2020 at 01:06
Preview
JPEG Image - 1.30 MB - 12/31/2020 at 01:05
Preview
JPEG Image - 1.15 MB - 12/31/2020 at 01:05
Preview
JPEG Image - 1.24 MB - 12/31/2020 at 01:05
Preview
JPEG Image - 1.22 MB - 12/31/2020 at 01:05
Preview
View all 12 files
  • 2 × MM034202-8 Mems Microphone with analog output
  • 2 × as6200 i2c temperature sensor
  • 2 × VEMD8080 or VEMD8081 Photodiode
  • 1 × LP5562 i2c LED Drivers
  • 1 × ICM-20600 6-Axis IMU ( U3 )
View all 10 components
  • PCB Reverse Engineering
    txyz.info12/31/2020 at 01:25 0 comments
    PCB Delayering
    I was hoping to find marking codes on the BGA chips while decapping the main chip(SiP), but found nothing. So I decided to look inside the PCB layers and hopefully get some clues.
    The delayering process was straightforward, using Sandpaper, Double-sided tape, and a piece of glass on which I mounted an extremely thin PCB.
    PCB delayering was a success, I uncovered 3 part numbers:
    • U3 - IMU ICM-20600
    • U7 - flash memory MT25QU256ABA
    • U13 - battery charger BQ25125
    PCB has 5 copper layers, with the ground plane in the middle.
    Mics and strange Caps
    PCB reverse-engineering begins with a weird discovery:  a capacitor from flex PCB that is connected to the pin on BLE SOC U9, unusually far away from U9.
    Button
    Button connected to the main PCB with 2 traces from flex PCB, another strange design choice.
    i2c
    The chip design continues to get weirder: i2c lines are not connected to the pads on the right side! This means the second i2c temperature sensor located on flex PCB is useless.
    Flash memory
    All together with power lines
    Future plans
    "2008-002100-21 Project-D" has a lot of test points where I want to connect JTAGulator and GoodFET, in order to do this I need to order another Halo.
View project log
turnkit wrote 08/10/2023 at 00:28 point
some Halo software sniffing and the like on reddit:
https://www.reddit.com/r/AskReverseEngineering/comments/zkc3fp/amazon_halo_app_to_intercept_halo_band_and_view/
Justin Kenny wrote 04/09/2021 at 23:02 point
Regarding the "strange cap", it's probably a pseudo differential routing for the microphone signal like what is described here: https://ez.analog.com/audio/f/q-a/3326/adau1961-alc-function
For the "missing" I2C did you check other layers?
Jimbo Navarski wrote 01/05/2021 at 20:51 point
FYI U1 is definitely the MAX86141 and those two PPG LEDs look like Osram SFH7016 and CT DBLP31.12
txyz.info wrote 01/05/2021 at 21:57 point
Hey, you are right! I just double-checked all 3 parts & updated my component list
Mike Szczys wrote 12/31/2020 at 15:57 point
Whoa! This is an incredible teardown. I'm amazed at the level of detail, nothing can stop you from unlocking the secrets. I really enjoyed this, thank you!
