...now features fisheye optics
07/16/2014 at 19:10 • 0 comments -
*hooray* worlds first mjpeg balcony pumpkin cam
07/08/2014 at 16:15 • 0 commentsMeanwhile...
My pumpkin population exploded a bit, my whole balcony is now a pumpkin jungle! How to supervise them and check if they broken out and try to take over the world? Digitus IP cam to the rescue!
Hmm.. ok I need to get a fisheye lens, else it is not possible to see the whole picture... (already ordered, crappy 5 eur toy for smartphones :D)
No, I won't let you access my private CCTV pumpkin cam ;) But here is PHP code to build one yourself...
<? function get_one_jpeg() { $addr = gethostbyname("INSERT HOSTNAME OR IP HERE"); $client = stream_socket_client("tcp://$addr:4321", $errno, $errorMessage); stream_set_timeout($client,0,50000); fwrite($client,"0110\n"); $header = fread($client,4); $payload_size = unpack("n*",$header)[1]; $bytes_to_go = $payload_size; $readmore = true; $partsize = 512; $payload = ""; #header('Content-Type: image/jpeg'); while($readmore) { usleep(1000); $rcvdata=fread($client,$partsize); $payload.=$rcvdata; $bytes_to_go-=strlen($rcvdata); if($bytes_to_go <= 0) { $readmore = False; } } fclose($client); return $payload; } # Used to separate multipart $boundary = "my_mjpeg"; # We start with the standard headers. PHP allows us this much header("Cache-Control: no-cache"); header("Cache-Control: private"); header("Pragma: no-cache"); header("Content-type: multipart/x-mixed-replace; boundary=$boundary"); # From here out, we no longer expect to be able to use the header() function print "--$boundary\n"; # Set this so PHP doesn't timeout during a long stream set_time_limit(0); # Disable Apache and PHP's compression of output to the client @apache_setenv('no-gzip', 1); @ini_set('zlib.output_compression', 0); # Set implicit flush, and flush all current buffers @ini_set('implicit_flush', 1); for ($i = 0; $i < ob_get_level(); $i++) ob_end_flush(); ob_implicit_flush(1); # The loop, producing one jpeg frame per iteration while (true) { # Per-image header, note the two new-lines print "Content-type: image/jpeg\n\n"; # Your function to get one jpeg image print get_one_jpeg(); # The separator print "--$boundary\n"; usleep(100000); } ?>
MJPEG code taken from http://ben-collins.blogspot.de/2010/06/php-sending-motion-jpeg.html , thank you Ben!
