This platform was created to allow modular development and experimentation of robotics in python / C++ using the Raspberry Pi and Arduino.
It is currently configured as a bipedal companion robot.
Features
Personality: Variables that are affected by external stimuli affect behaviour.
Facial detection and tracking: using the Raspberry Pi camera. Training algorithm allows the robot to learn new faces.
Servo control: control of up to 9 servos via an arduino serial connection.
Battery monitor: both external and software integrated via the arduino serial connection.
Auto shutdown: GPIO 26 is wired to allow shutdown when brought to ground via a switch.
Buzzer: A buzzer is connected to GPIO 27 to allow for tones to be played.
Braillespeak: The buzzer uses tones to communicate words using a sequence of tones.
Motion Sensor: an RCWL-0516 microwave radar sensor is equipped on GPIO 13.
Stereo MEMS Mics: GPIO 18, 19 and 20 allow stereo MEMS microphones as audio input.
Speech Recognition: enabled whenever a face is visible.
Power saving relay: connected to disable power to servos when not in use.
Neopixel: WS1820B support is included via the Pi GPIO pin 12. Unfortunately to support this you must disable audio on the Pi.
Dan Makes Things
Max.K
ACROBOTIC Industries
swartskaap
I've watched all of your videos and I have subscribed. this is an awesome project!
I've been wondering what I would need to learn in order to begin projects like this.
