TESTED_FLIGHTcontrolbirdfishv2_flightFixed.txt
Flight tested.. With one error fixed.
plain -
9.94 kB -
01/10/2021 at 01:10
Download
controlParaSoundingv4.ino
Latest version.. With lessons learned implemented
ino -
9.57 kB -
01/10/2021 at 01:10
Download
taking 3d surface and making flat pattern
JPEG Image -
75.06 kB -
01/08/2021 at 00:07
Preview
quadwing.f3d
Design of my own wing. cut files below are via exact flat. From 3d surfaces.
fusion -
7.62 MB -
01/08/2021 at 00:05
Download
celldxfs.f3d
A Wing design cutfiles with seam allowance Fusion360 archive
fusion -
806.60 kB -
01/08/2021 at 00:00
Download
Ribs for wing design
Portable Network Graphics (PNG) -
202.30 kB -
01/08/2021 at 00:00
Preview
3celltop.dxf
AutoCAD DXF -
17.73 kB -
01/08/2021 at 00:00
Download
1cellbottom.dxf
AutoCAD DXF -
5.31 kB -
01/08/2021 at 00:00
Download
2celltop.dxf
AutoCAD DXF -
17.88 kB -
01/08/2021 at 00:00
Download
2cellbottom.dxf
AutoCAD DXF -
6.25 kB -
01/08/2021 at 00:00
Download
1middletop.dxf
AutoCAD DXF -
17.02 kB -
01/08/2021 at 00:00
Download
3cellbottom.dxf
AutoCAD DXF -
9.75 kB -
01/08/2021 at 00:00
Download
5cellbottom.dxf
AutoCAD DXF -
21.92 kB -
01/08/2021 at 00:00
Download
4cellbottom.dxf
AutoCAD DXF -
15.64 kB -
01/08/2021 at 00:00
Download
4celltop.dxf
AutoCAD DXF -
11.15 kB -
01/08/2021 at 00:00
Download
6cellbottom.dxf
AutoCAD DXF -
21.92 kB -
01/08/2021 at 00:00
Download
5celltop.dxf
AutoCAD DXF -
18.04 kB -
01/08/2021 at 00:00
Download
7cellbottom.dxf
AutoCAD DXF -
11.63 kB -
01/08/2021 at 00:00
Download
7celltop.dxf
AutoCAD DXF -
21.64 kB -
01/08/2021 at 00:00
Download
ribprofile.dxf
AutoCAD DXF -
16.65 kB -
01/08/2021 at 00:00
Download
6celltop.dxf
AutoCAD DXF -
16.17 kB -
01/08/2021 at 00:00
Download
ribprofilecutout.dxf
attachment patch support
AutoCAD DXF -
22.43 kB -
01/08/2021 at 00:00
Download
ribprofilereinforce.dxf
AutoCAD DXF -
29.54 kB -
01/08/2021 at 00:00
Download
servoarm_birdfish4_bigV2.stl
Birdfish arm for the big servos.
Standard Tesselated Geometry -
294.71 kB -
01/07/2021 at 22:11
Download
servoarm_birdfish3.stl
Normal Birdfish arm for payloads less than 1.5kg. and windspeeds under 20mph. otherwise there is not enough control authority.
193.25 kB -
01/07/2021 at 22:11
Download
bigservoredesign.stl
The original Box shape derived from the foam high altitude design, but with larger servo placement for high winds, or wing loading.
5.65 MB -
01/07/2021 at 21:49
Download
birdNewV6.stl
Last box shape design derived from foam high altitude design. Room for switches, speed system. Some other things..
3.38 MB -
01/07/2021 at 21:49
Download
coreV2_power_serv.stl
EDF design more reinforcement. Ended up using bottom reinforcement to add weight to properly load larger wings.
1.09 MB -
01/07/2021 at 21:49
Download
core_power_serv.stl
First EDF design.
909.26 kB -
01/07/2021 at 21:49
Download
