TX8 Specifications:
- 65C02 @ 2MHz CPU, 4MHz possible with a few updates
- 32KByte ROM (Flash memory)
- 128KByte RAM (SRAM)
- 2 RS232 serial ports
- 2 Joystick Ports (With real analog input)
- External I2C Port
- YM2149F and SID (either 6581 or 8580) sound chips
- TMS9929A graphics controller with TMS-RGB video encoder
- 32 KByte Graphics memory bank switched
- Internal W65C22 keyboard controller
- Compact Flash Card slot
Address map The computer makes use of the entire addressable area that the 6502 processor provides. |-------------| | FLASH | 256 byte |-------------| | IO | 256 byte |-------------| | | | FLASH | 15872 bytes FLASH | | |-------------| | | | 16KByte | | banked | 16384 bytes RAM | RAM | | | |-------------| | | | | | | | | | 32Kbyte | 32768 bytes RAM | RAM | | | | | | | | | |-------------| RAM The computer is designed to take up to 128Kbyte of RAM using a monolithic 128Kbyte device. The lower 32Kbyte (0000 - 7FFF) is a contiguous block. The following 16Kbyte area (8000 - BFFF) is a windowed (banked) area where any 16K boundary memory chunk from the available memory can be mapped in. 4 bank select bits are used to select the bank the user wants to have access to. The first 64 Kbyte of the 128Kbyte is linerly mapped to the 64K memory area of the 6502. All accesses between 8000 up to BFFF will create a banked access. A banked access will map the bank select bits onto addresses A14-A18 instead of the regular address bus thus creating an access to the selected bank. Note that the entire memory can be selected, including the parts that is in regulate memory space (0000-7FFF, C000-FFFF). FLASH The system also contains a small flash memory (16KB) that should be used be used for early boot. This memory can be disabled allowing the system to access the RAM that is available from C000-FFFF. The signal SHDW (Bit 6 on the output port of the SCN2681) is used to enable or disable the ROM/FLASH memory. The output pin is set to 1 (logic high) after reset and should be set to 0 to disable the ROM memory. The design idea was that when the ROM is enabled, the RAM at the same address can still be written to which would enable the user to copy the content the ROM I/O Space 256 bytes is allocated for hardware peripherals (I/O). This area is located from FE00 - FEFF. Address range size Description * FE00 - FE0F 16 W65C22 keyboard controller. * FE10 - FE1F 16 SCN2681 Dual UART controller. * FE20 - FE2F 16 PCF8584 I2C controller. * FE30 - FE3F 16 YM2149 Audio controller. * FE40 - FE5F 32 SID6581 Audio controller. * FE60 - FE5F 16 TMS9929ANL Graphic controller. * FE70 - FE6F 16 ADC0801 Analog to digital converter. * FE80 - FE7F 16 Compact Flash / IDE controller. * FE90 - FE9F 16 RTC72421 Real time clock * FEA0 - FEFF 96 Experimental I/O BIOS The BIOS provides the system with basic input, output and graphic functionality. 128 call vectors are defined in ROM located from FF00 up to FFFF. The top three vectors are the processor NMI, RESET and IRQ vector and the rest are BIOS function calls. A call to the BIOS is done with the following instructions: BIOS_CALL: JMP ($FF00, X) ; This function will call the BIOS ; pointed to by the the X register. The user will then use the following instructions to call the BIOS. LDX #BIOS_GETCHAR JSR BIOS_CALL * Notice this uses 65C02 specific instructions so this will not work on older 6502 NMOS processors.
Second stage of the testing was to install the DRAM's and make sure that I can write data and read it back properly. So I wrote a short test program that wrote a test pattern to the memory and verified that it would read back properly. I let the program run for a few hours and no errors were found during this time. I also verified all the setup and hold time parameters with an oscilloscope, just to put my mind at ease. The VDP seem to perform significantly better than specified which means the timing margins are very good.
Erik Piehl
Anders Nielsen
