The first prototype samples of the TMS-RGB module for the TMS9929A were finished today. and they look great. Now all I need is the actual TMS9929A devices to start testing everything out.
Looks great doesn't it.
I take no credit for the actual design, it was done by Nicholas Pigdeon (@npigdeon) and his story is available on http://tms-rgb.com. I only re did the layout using smaller components with the aim to make it a very small module. I could probably have shaved off a few mm's more from it but I was satisfied with the result.
Testing will start as soon as I have a 9929A running in the TX8 computer.
