arduino_2_4_filtering.zip
messy code that does data collection, both of raw, and filtered mm distance based on voltage delta limits.
Zip Archive - 15.70 kB - 02/04/2021 at 11:16
Download
filteredeffect.xlsx
filtered and unfiltered just by voltage delta.
sheet - 257.13 kB - 02/04/2021 at 11:13
Download
reduceNoise1.xlsx
shows noise reduction by voltage delta and laser power output. reduced noise variation by ~2.2 (max-min)=31.8
sheet - 617.20 kB - 02/02/2021 at 19:21
Download
reduceNoise2.xlsx
noise reduction using inversion of high frequency in signal. reduced noise variation by ~20 (max-min)=13.8
sheet - 541.32 kB - 02/02/2021 at 19:21
Download
mm_volt_laserPower.xlsx
noise reduction, however it is from static data. noise phase and offset as well as noise gain change with actual data. but the noise is a few things. laser power fluctuation (but usually in spec) and voltage spikes.
sheet - 108.99 kB - 01/30/2021 at 10:27
Download
sat23.csv
count 30samples a second, mm distance, temp in c, vofchip,laser output power
Comma-Separated Values - 619.92 kB - 01/23/2021 at 22:38
Download
raw_measurment2_21_21.csv
raw measurement at ~30-50 times a second. raw voltage data, and raw range data in mm, temp is filtered but changes so slowly. numbers count is Na because it is not in seconds but is raw values.
Comma-Separated Values - 577.91 kB - 01/22/2021 at 08:33
Download
distance_temp_count_adc.txt
raw file showing 1 hour of samples with distance, temp, count in seconds, and vcc of sensor chip. these are filtered results
plain - 197.25 kB - 01/21/2021 at 02:35
Download
time_temp_distance.csv
cvs file time in seconds, temp in c, and distance in mm over 528 minutes in
1 second increments of sensor with a drop overtime of about 4deg c
and a change in measurement of about 0.7mm
Comma-Separated Values - 689.56 kB - 01/20/2021 at 21:45
Download
filter_sensorWtemp1s.zip
arduino code i used for temp measurement. the gnd lead of sensor was placed on an i/o pin to gnd so calc was slightly different as voltage is between 0.6 ad 1v on pin, but temp variation is consistent with actual temp of room. you will see this in the code. my sensor was about 15k, and temp was consistent with temp measured by thermometer. what is most critical is the temp and temp variation. you can use your own thermister and code to check and verify. settings need to be changed in code to your sensor. the example i used was from https://playground.arduino.cc/ComponentLib/Thermistor2/
Zip Archive - 14.66 kB - 01/20/2021 at 20:25
Download
distaneandtemp.txt
31725 seconds or 528 min, or 8.8hrs ov overnight temp and measurement data together as temp dropped from 1am to 10am
plain - 1.59 MB - 01/20/2021 at 20:21
Download
room_temp_hour_no_heat_9pm.txt
this is temp of my room for an hour at night, looking at temp fluctuations with door open, and no air movement in the room . just looking at over time fluctuations within an hour
plain - 119.88 kB - 01/20/2021 at 20:19
Download
with_200wheaternearby1hr.txt
this is sensor with a 200w heater nearby and on. i just wanted to see how much temp changes from a nearby small heater. not much.
plain - 123.20 kB - 01/20/2021 at 20:18
Download
