(25 May update: side options)
This very low cost linear slide design does most of the work of my #Minamil project - a “minimal CNC mill”. I hope this rendition of a single isolated unit will serve two purposes:
- Share this idea as a concrete, ready-to-use example
- Isolate and simplify the hard part of describing how to make a Minamil-like machine
Maybe you can use this to reduce the entry cost of some other project!
Video showing load carrying capacity and repeatability (>10 kg, <10 μm):
If you want to try one of these (or three) for yourself, check out detailed build instructions over at Instructables.
The CAD model is configurable for:
- material thickness
- handwheel or stepper drive
- driving/driven side
- application option, selectable for each side:
A couple of example configurations:
handwheel drive • heavy load configuration
stepper motor drive • fixed point-of-action configuration
The moving load/fixed PoI distinction illustrated:
Where this comes from, and i̶s̶ slowly g̶e̶t̶t̶i̶n̶g̶ got back to:
#Minamil: a minimal CNC mill. And friends.
But HaD.io projects can include instructions...
Why send traffic elsewhere instead of writing instructions here in sunny HaD? Because the longish 'ible was a mess until it was done and I didn't find how to save unpublished instructions-in-progress here.
Paul McClay
Kārlis
Jose Ignacio Romero
Pretty cool design with the extending table, I have never seen that before. It surely has some drawbacks, but it solves the problem of linear slides wasting lots of space.
