lightDomeSpiky.stl
100 gram, 6 inch radius variant! It's called HACKaday! This is a really bad, basically hacked together 3D model of a low material variant which requires fiddling with cura parameters, I changed the line width to 0.3mm and the slicing tolerance to "middle" but was able to get the LED's in by pushing a little harder. Recommended for overhead lights where you want to work on something looking through a microscope and need room to stick your hands in.
Standard Tesselated Geometry -
36.53 MB -
02/12/2021 at 16:13
