^6 SPI Checked With Raspberry Pi
07/18/2018 at 19:26 • 0 commentsThe unit under test is at address '1'. So first I need to bootload its RPU controller (an RPUno^8) with SpiSlv.
To do that I set the booload address on the shield that is connected to the host which will build SpiSlv and upload the firmware. Guess I will just use the new I2C1 interface to do this.
# first set user premision to use the SPI port sudo usermod -a -G spi rsutherland # logout for the change to take python3 import smbus bus = smbus.SMBus(1) bus.write_i2c_block_data(42, 0, [0]) chr(bus.read_i2c_block_data(42,0, 2)[1]) '1' # with command 0 on I2C1 the local address is showed as ascii '1' or 49 bus.write_i2c_block_data(42, 2, [0]) chr(bus.read_i2c_block_data(42,0, 2)[1]) '0' # command 2 on I2C1 showed the bootload address which was '0' # which will be canged to '1' with command 3 bus.write_i2c_block_data(42, 3, [49]) chr(bus.read_i2c_block_data(42,0, 2)[1]) '1' bus.write_i2c_block_data(42, 7, [0]) print(bus.read_i2c_block_data(42,0, 2)) [7, 0] # command 7 was used to clear the local status bits, the host lockout bit was set at power up. exit() # next check that RPU '1' is blinking fast picocom -b 38400 /dev/ttyAMA0 ... Terminal ready # C-a, C-x. # now change the working directory to where SpiSlv is and then build and upload cd ~/wher_you_told_git_to_clone/RPUno/SpiSlv make bootload ... avrdude done. Thank you. gcc -o spidev_test spidev_test.c chmod ugo+x ./spidev_test # trun on the RPU SPI port picocom -b 38400 /dev/ttyAMA0 ... Terminal ready /1/id? {"id":{"name":"SpiSlv","desc":"RPUno (14140^9) Board /w atmega328p","avr-gcc":"4.9.2"}} /1/spi UP {"SPI":"UP"} # C-a, C-x. # test with ./spidev_test -s 1000 -D /dev/spidev0.0 ./spidev_test -s 10000 -D /dev/spidev0.0 ./spidev_test -s 100000 -D /dev/spidev0.0 ./spidev_test -s 250000 -D /dev/spidev0.0 ./spidev_test -s 500000 -D /dev/spidev0.0 # next test fail on my setup which is using a weak pullup # for SCK, nSS, and MOSI that input into a ATmega328p ./spidev_test -s 1000000 -D /dev/spidev0.0 ./spidev_test -s 2000000 -D /dev/spidev0.0The test output should look like this
spi mode: 0 bits per word: 8 max speed: 500000 Hz (500 KHz) 0D FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF DE AD BE EF BA AD F0
The maximum speed seen is 500kHz. Adding 3k Ohm pullup on R32, R34, and R37 should allow higher speed.
^6 Serial Checked With Raspberry Pi
07/18/2018 at 03:26 • 0 commentsThe Remote firmware has the Raspberry Pi locked out from using the serial connection, but with I2C1 it can be enabled. One of the status bits is for host lockout. I2C command 7 is used to set that status bit.
python3 import smbus bus = smbus.SMBus(1) #write_i2c_block_data(I2C_ADDR, I2C_COMMAND, DATA) bus.write_i2c_block_data(42, 7, [0]) #read_i2c_block_data(I2C_ADDR, OFFSET, NUM_OF_BYTES) #OFFSET is not implemented print(bus.read_i2c_block_data(42,0, 2)) [7, 0] exit() picocom -b 38400 /dev/ttyAMA0 ... Terminal ready /1/id? # C-a, C-x.
Once the host lockout is clear the Raspberry Pi can bootload the address set with command 3 (see Remote). The Raspberry Pi will need to use its RTS handshack lines for avrdude to work.
^6 I2C1 Checked With Raspberry Pi
07/17/2018 at 21:45 • 0 commentsToggle is a little Python program to run on a Raspberry Pi that has been setup as follows.
sudo apt-get install i2c-tools python3-smbus sudo usermod -a -G i2c rsutherland # logout for the change to take i2cdetect 1 WARNING! This program can confuse your I2C bus, cause data loss and worse! I will probe file /dev/i2c-1. I will probe address range 0x03-0x77. Continue? [Y/n] Y 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- 2a -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- --
The 328pb I2C1 port is connected to the Raspberry Pi, but the data echo I got back was [0, 0xFF].
The bare metal should have returned [0, 0xFC] so what has gone wrong? Well, nothing. I sent the bare metal [0, 0x03] and the 328pb inverted the bits of the second byte for the echo that way I could see it had done something. The SMBus block read function is a second I2C transaction and it runs the twi received event a second time after the block write transaction (and before running the transmit event). Since I want to echo the data from the first transaction, I needed to preserve that old data from the first I2C transaction when (or before) the event for receiving the second transaction data occurs. Finally when the second transaction causes the transmit event I can pass the old data from the first receiving event.
So to sum it up, there seem to be two receive events and one transmit event when the Raspberry Pi does a write_i2c_block and a read_i2c_block.
^6 I2C1 Checked With i2c-debug
07/14/2018 at 06:17 • 0 commentsBlinkLED allows the I2C1 port (e.g. the secnond I2C port on ATmega328pb) to interface with a host SBC.
The i2c-debug firmware can be used to test the I2C1 port, its address is at 0x2A. The Uno clone running i2c-debug has another I2C interface at 0x29.
picocom -b 38400 /dev/ttyUSB0 ... Terminal ready /0/iscan? {"scan":[{"addr":"0x29"},{"addr":"0x2A"}]} /0/iaddr 42 {"address":"0x2A"} /0/ibuff 0,3 {"txBuffer[2]":[{"data":"0x0"},{"data":"0x3"}]} /0/iwrite {"returnCode":"success"}blinking has stopped
/0/ibuff 0 {"txBuffer[2]":[{"data":"0x0"}]} /0/iread? 2 {"rxBuffer":[{"data":"0x0"},{"data":"0xFC"}]}Note: I incuded the command byte befor reading the data because I think that is what SMBus does.
^6 ISCP ATmega328pb
07/14/2018 at 06:12 • 0 commentsYes it works, but...
There is a but.
The Debain mainline starting at buster allows using the Atmel support packages, so that is what I am doing, check a Makefile to see how it is used. Also avr-libc assumes one TWI port. TWSR is not defined, but we have TWSR0 and TWSR1.
#define TW_STATUS (TWSR & TW_STATUS_MASK)
It has a new signature and fuse at efuse bit 3 for clock failure detection, so the avrdude config needspart parent "m328" id = "m328pb"; desc = "ATmega328PB"; signature = 0x1e 0x95 0x16; ocdrev = 1; memory "efuse" size = 1; min_write_delay = 4500; max_write_delay = 4500; read = "0 1 0 1 0 0 0 0 0 0 0 0 1 0 0 0", "x x x x x x x x o o o o o o o o"; write = "1 0 1 0 1 1 0 0 1 0 1 0 0 1 0 0", "x x x x x x x x x x x x i i i i"; ; ;I am not using SPI or the other serial port from the manager on this board so best look at MiniCore for info on those.
When ISCP is used to program the manager its control of the shutdown pin will stop and the pin will float. The Raspberry Pi should then halt, and nothing bad should happen, but it means the Raspberry Pi can not be the ICSP tool.
^5 Remote Reset
04/03/2017 at 21:26 • 0 commentsI used an RPUftdi^4 to do a remote reset of an RPUno^6 with an RPUadpt^5 shield. The RPUno was also wired to a K3^2 board. A quick video shows picocom used to do the remote reset.
After the reset, the bootloader runs for a few seconds and then passes control to the Solenoid firmware which reads an address from the RPUadpt shield over I2C and cycles through each latching coil to place them in a known state. Reading the address from RPUadpt also lets the bus manager on that board broadcast a byte on the RS-485 bus management pair (DTR) that ends the lockout placed on other devices to allow a point to point bootload connection (i.e. a return to normal point to multipoint mode).
^5 Bus Termination
04/03/2017 at 21:25 • 0 commentsThe RX, TX, and DTR pair need a 100 Ohm termination on each end of the CAT5 daisy chain. There are places on the board to solder the resistors, they are on the RPUftdi, but for an RPUadpt an RJ45 plug allows adding to the daisy chain without soldering. I'm going to supply this for now since it is how I'm using the RPUadpt board.
^5 South Wall Enclosure
04/03/2017 at 21:22 • 0 comments
ronald.sutherland
