Custom tool
02/04/2021 at 13:21 • 0 commentsBattery tabs welding holder.
Magnetic charging cable V1.0
02/04/2021 at 13:08 • 0 comments![]()
3D printed mold inserts
02/04/2021 at 13:07 • 0 comments![]()
PIXE one
02/04/2021 at 13:06 • 0 comments![]()
DFM is a thing
02/04/2021 at 13:05 • 0 commentsThis is one of the first versions of PCB panel that i have designed for this project. Multiple device modules are fitted on to a single panel, so, one panel, one device.
Some assembly required
02/04/2021 at 13:00 • 0 commentsInternal body of the device has been assembled, and a battery pack mounted to the plastic shell.
I have designed these two PCBs to mate with just a solder joints, as it turns out, it was a bad decision. The round PCB is a battery charging and monitoring module, flat one is power distribution board that connects to a DC-DC converter circuit, and has few NTCs to monitor battery temp.
The year was...
02/04/2021 at 12:51 • 0 commentsThe year was 2018, first PCBs have arrived...
Nikola Secerovski
