85W Cowboy Studio CFL & Artemis Nano comparison to 3.7V battery
03/05/2021 at 22:51 • 0 comments![]()
Sparkfun Artemis Nano LED powered by ordinary lightbulb
03/05/2021 at 20:35 • 0 commentsSparkfun Artemis Nano https://www.sparkfun.com/products/15443
Powered by DFRobot Solar Power Manager Micro
https://www.dfrobot.com/product-1781....
Monocrystalline Silicon Solar Panel 2V 160mA 50*50mm& 800 Lumen Philips 10.5W bulb 2700K.
The next step is to get the blue light that flashes when it boots with a standard 3.7V battery & recharge the battery at the same rate it discharges. A larger solar panel will easily work, but I had to unplug it because the Nano immediately started smoking, not realizing I was using the wrong 4.4V out with an Adafruit Solar Lipo Charger. Really important tip: Make sure you have the right regulated output or it will fry the MCU
I attended a webinar by E-peas, Epishine & Cap-XX, and found this slide helpful
Parallel Project
03/01/2021 at 01:30 • 0 commentsA parallel project by Alexander Soto that I am contributing to: https://alexsoto.dev/community-built-eink-laptop.html
which may cross paths in the future with the autarkic project.
AM1454CA current test
02/26/2021 at 01:55 • 0 commentsTesting new multimeter
1st Indoor Test w/Led On
02/18/2021 at 19:46 • 0 comments2/18: 1st successful test of any indoor panel: Panasonic AM-1816CA with Waveshare Solar Power Manager (even though the latter is for 6V-24V) the AM1816CA is 4.9V.
Cowboy Studio 85W (450W equivalent) CFL was used.
https://www.waveshare.com/solar-power-manager.htm
The boot light (top right corner) also flickers on with enough light, but hasn't been able to charge a 3.7V battery yet.![]()
Giovanni
