21Install the Two Thirds
I found a couple of long thumb screws to hold the assembled product to the chassis.
22Install the bolts through the radiator mount
Gently place the chassis on its side. Pull out the air filter. Grab six M4x12 Flathead bolts. Gently screw them into the assembled product. Depending on how tight you engineered those cage nuts, they may or may not pop out if you use too much force.
23Install the PDB
Before:
After:
Also, put the chassis on its side and install the remaining two M4 Flathead bolts into the PDB Third. -
24Test the slides
Slide the air filter into the chassis' bottom side. It should not catch on the M4 Flathead bolts. Also slide the power supplies into the assembled product. They should click home happily.
25Pull your 24-pin and EPS12V cables through the side
The 24-Pin and EPS-12V cables on this PDB are short, but that's why you bought the ATX PSU cable extension in step 3.
26Attach the ATX PSU extension cables
Route the cable up the back side of the case where they won't be seen.
