All the documentation needed to build the SSP (Standard Parallel Port) Adapter board (A240721-R270921) including schematic, PCB assembling guide, Gerber files for PCB production. PCB is 55mm x 60mm 2-layers.
x-zip-compressed -
747.10 kB -
11/06/2021 at 10:10
The IOS in executable format (.HEX). This executable file is intended for the use with MPLAB IPE (or any other equivalent SW) to program the PIC MCU directly.
The sources for the IOS (with the needed libraries). Unzip into a folder and open with MPLAB X IDE (I've used version v5.45. No warranty that it will work "out of the box" with newer version of MPLABX IDE!). IOS must be uploaded into the PIC18F47Q10 flash. See the CHANGELOG section on main.c source for more info on changes.
PIC programmer using an Arduino Uno. All the needed SW/FW with my changes already applied, and all the documentation of the "ICSP Shield" board (A170421).
x-zip-compressed -
281.60 kB -
09/24/2021 at 10:33
