The simplest way to read serial data is to use Miniterm:
I have made one Serial Plotter to plot data:
Code
And simple Python GUI:
Code on Github.A device that measures the ambient temperature in the environment in which it is located. And displays it on the screen.
Since the two methods give you readings a couple degrees C apart, it's not clear that simply averaging them will give a better number than either one alone (which one??).
For a limited range (around room temperature), if you want accurate readings, why not forget about Steinhart-Hart or Beta and just calibrate the thing for the actual sensors you are using?
