Reverse Engineering The Weather STAR 4000
The Weather STAR 4000: A Journey of reverse engineering the hardware to an iconic machine of the 1980s/90s.
Anyone in the USA who grew up in the 90s watching The Weather Channel, whether you got into meteorology, or technology, or just was an enthusiast of weather. Likely remembers this machine.
For those of you who don't know, This machine powered "The Local on the 8s" in the end of the 80s through the early 2000s, the system finally went offline and was replaced with newer systems by the 2nd half of 2014. This information in detail can be found at twcarchive.com. This machine was considered iconic during the time period.
However, the software was volatile and was lost with time. Therefore, it requires reverse engineering to make it run again as it once did. Whether it be nostalgia, or novelty, or both! As a retro-computing and weather enthusiast, I might as well get it working again. right?
This project is basically a Blog that will go into detail on what I went through to achieve the glory of reverse engineering the system to make it run again.
We bring this 1980s machine into the modern world as an IoT device to receive data and render presentations like it used to, once again... Bridging the digital divide between 68K satellite-era hardware and the internet :-)
Schematics.7z
Mostly complete reverse engineered schematics of the CPU, Graphics, I/O, and Data cards.
7-Zip - 2.76 MB - 05/24/2023 at 22:58
Download
4000pals.7z
JED fusemaps dumped from the PAL and PLS chips using a proper programmer.
7-Zip - 2.96 kB - 05/24/2023 at 22:56
Download
WS4000 ROMs.7z
This is the ROM and EEPROM Dumps of the 4000 including all the IDA disassemblies.
7-Zip - 644.61 kB - 02/12/2023 at 00:25
Download
  • ROM Bootloader: Bootstrapping protocol
    techknight • 07/17/2022 at 01:21 • 0 comments
    Now that we were able to get some basic ROM routines working, setting up the 68K in an initial state and testing RAM, verifying that all of the hardware is operational, we can move onto writing yet another protocol for handshaking between the data card and the CPU/Graphics card.
    Some thought had to be paid attention here. It is not as simple as just writing a little protocol to read out the FIFO and write those values into RAM and execute. It is a bit more involved than that.
    To understand why, we need to take a look at the system architecture again:
    So if we take a look at this, we basically have two system busses here. the main system bus which is the VME bus, is also part of the main CPU card and contains the RAM for the whole system, and its ROM and EEPROM is part of the main address space and can be accessed by any bus mastering cards at any point.
    But, the Graphics Card also has its own system bus. it has its own ROM, its own RAM, and VRAM.
    However, the system bus for the GPU isnt the same system bus as the main bus. it has its own. Therefore, the Graphics Card can only access the main bus by a 128K assigned address block and a paging register.
    This poses a problem because the operation is one-way. the main CPU cannot access the graphics card in any way. only the graphics card can reach out and do anything.
    However, we have bi-directional interrupts between the graphics card and the main CPU. the main CPU can send an auto-vectored interrupt to the Graphics Card, but also the Graphics Card has an IVEC register and can send manually-vectored interrupts back to the CPU card. This allows the graphics card to target a specific vector over on the CPU and run that code block, and the CPU can send an interrupt back at the graphics card at any time.
    Great for handshaking between the CPU and the GPU. Buuuuut there's a problem with this.
    The data card.... the data card only has specific registers exposed to the bus as we talked about previously. the data card itself cannot master the bus or read/write to it on its own. it can only load up registers, and its up to another master on the system bus to read/write the card. it is peripheral only whereas the GPU can be a bus-master.
    However... the issue is the data card interrupt only goes back to the CPU. the graphics card is unaware what is going on with the data card at any point, no way for the graphics card to know what the data card is doing unless it polls it.
    So circling back around, this is the issue we need to keep in mind when designing a bootstrapping protocol for the ROM on the CPU and graphics cards.
    Now, there are a couple different approaches we can take here. One, we could download the graphics card binary to the CPU's shared RAM space, and then tell the graphics card via interrupt to download its binary from main system RAM. In fact, this is how they did it originally.
    Or, we can simply have the Graphics Card reach out directly on the system bus to the data card and it can handle the data card on its own which removes the burden of data handling from the CPU to get to the graphics card.
    Problem with the second approach is once again the graphics card cannot easily see whats going on with the data card unless its constantly polling. Polling is a bad idea because it has to take over the bus to do it. this will impede main CPU operations and slow things down.
    So we work around it by routing interrupt traffic. So we design a specific command in the CPU ROM protocol that's specifically designed to bootstrap the graphics card.
    Instead, we load the data card FIFO with a chunk of binary data meant for the graphics card, then shoot an interrupt to the main CPU. the main CPU then sees the vector and the CPU simply passes the interrupt down to the graphics card. so the graphics card's bootloader knows the next chunk of data is ready. Clever.... So this is the method we will go...
  • The bootloader
    techknight • 07/16/2022 at 14:52 • 0 comments
    So in order to make this system useful in any way and now that we are capable of assembling and running code, we need to come up with some method of booting the system into an initial state and running it.
    Because the ROMs are only so large, and the running program would be very dynamic especially during the debugging stage, the current line of thinking would be keeping the ROM very simple in nature with basic self tests/checks, and downloading binary into RAM and executing it.
    One method would be using a pre-made 68K ROM monitor that would have been made back in the 80s at least, and using the RS232 port on the back of the unit. But, i would have to modify the codebase for the architecture we are dealing with, and writing a driver for putchar, getchar, etc for this particular I/O card and protocol. That is certainly an option!
    But... In typical me fashion, I decided to roll my own. The original ROM is very specific to the original data card and how it worked, plus there are other goodies in the original ROMs that we will get to later like VRTX-32.
    The first part of this though is to do some basic stuff like testing RAM, spitting out characters from the RS232 port on the I/O card, things like this. So I wrote all the pre-startup and initialization code first.
    This required a lot of debugging, and re-burning ROMs back and forth.
    Because I needed to see each stage of the ROM startup process with some visual indicator, Remember the bargraph LED display I put onto the Data card? Yep! that came in handy...
    For each routine I wrote, I bumped the LED indicator by one. this way, if something were to crash/die I knew where approximately, just not what...
    It was time to start writing the framework of the ROM/Bootstrapper
    The beginning of the startup code for the CPU's ROM looks about like this:
    That is basically it. Now that we have the startup code written and lots of debugging over and over later, we get this:
    Presto! we have a very primitive bootloader that is able to output to the RS232 port as well as indicate a status of where things are on the LED bargraph display.
    Eventually I added RAM test routines which were a bit slow, but they worked:
    And that's it for the first part of the ROM bootloader. Again, we have not working on the GPU side yet but that will likely be much of the same.
    Next we need to write the handling protocol between the bootloader and the data card.
  • Hello World
    techknight • 07/16/2022 at 13:37 • 0 comments
    So up until this point, I had no knowledge or prior experience writing any 68K program C, ASM or otherwise.
    My background in programming up to this point was Visual Basic 6/VBScript and microcontroller ASM, as that's what I grew up with, VB being taught in school and ASM being self-taught. I didn't even know C yet, but i knew PHP and PHP is a C-like syntax.
    Now that the hardware engineering and reverse engineering is out of the way, we need to get some sort of program running on the 68K hardware to some degree.
    In the beginning, I chose ASM so I could get familiar with the 68K, and we needed a bootstrap anyways. We need some method of getting code running on the hardware and eventually downloaded into the machine to run in RAM.
    So, first and foremost there were two websites (one appears defunct now with broken SSL and blocked by malware services) that I learned a lot of programming aspects of the 68K and learned about VASM which is an assembler that is compatible with the m68K arch:
    https://web.archive.org/web/20220606083430/https://www.chibiakumas.com/68000/
    https://mrjester.hapisan.com/04_MC68/
    I decided to start with the CPU card, I will worry about the graphics card later. I wanted to start writing a hello world example, at least to keep the watchdog happy on the CPU card. If the CPU card stayed alive, I knew it was running my program.
    Since I had the I/O card protocol and firmware written, That was one of the first things I tested when I assembled my hello world example. I used the LEDs on the I/O card as a visual indicator that code was running, and I can write the status of the LEDs.
    Not only is the watchdog happy, but I was able to write a byte value to the I/O card using the protocol I created and turn on an LED!
    I know this isn't a whole lot of fanfare, but this was a MAJOR milestone. I now have code running on the 68K CPU's ROM that was assembled by VASM and can communicate with other hardware! Now we have the proper building blocks for writing bootstrapping code and ultimately getting this machine running again
    So, Hello World!
  • Designing a new data card
    techknight • 06/24/2022 at 18:01 • 0 comments
    In order to bring this project to the 21st century and make it as easy as possible to interface to modern data standards, we need to design a new data card.
    When i made the schematic for the original data card, i yeeted the audio circuitry because honestly I did not care as I didn't need as sophisticated of a circuit for the audio stages.
    At this point in time, the audio and warning circuits weren't even in my mind. The most important thing is how do I interface with the bus, and how/what do I use to get data into the system?
    The venerable Raspberry Pi has entered the chat...
    Yeah, that's right. yet another raspberry pi project. BUT... it is the most convenient tool to interface with the data card, and act as a host. downloading the system binaries, graphics assets, and data on the fly in one swoop during startup. It makes the most sense to me logically.
    So with our control host chosen, we need to design the data card around this concept.
    First thing I need to do is pick the design. Physically, it will be just like the original one as far as shape/size. But the electronics for interfacing to the bus are going to be interesting.
    However, i figured why not use the original stuff they already had? Thing is... unlike the I/O card dumpster fire, the data card must have been designed by a different engineer. it actually uses gated logic to interface to the 68K bus and its cycles, reading and writing out of latches and a FIFO. so CPU intervention isn't necessary.
    So, to start off the new design, lets just "copy and paste" the original bus logic.
    I kept the bus logic so original, that i even kept the original PALs! So you can just move the PALs over from the old data card onto the new prototype card.
    As you can see, I simply kept the same logic design as they had, I even pay this as a tribute to the original data card kind of as a nice send-off.
    We do need to make some modifications. First, I replaced the old FIFO with a much bigger one. I can load up to 4K chunks and then have the 68K read out that entire FIFO. This allows me to send data across the bus faster when i break large binary files up into 4K chunks versus 512byte chunks. alot less bus activity and back/forth negotiation.
    Also, the key here was to figure out how to interface this logic to the Pi. My thought process here was to eliminate the old 8044 MCS51 CPU and replace it with the Pi instead.
    However, anyone that has worked with a Pi, knows the GPIO is 3.3V. this is a 5V card so we need to design in some logic shifting circuitry:
    Which we have done here. Then, we just wire up the Pi's GPIO header into the logic level shifters which then wires up to the same spots the old 8051 used to be.
    Presto! we have now successfully wired up a raspberry pi GPIO into the old bus interface logic borrowed from the original card. In theory, this should work...
    This offers many benefits as in I dont have to design new logic circuitry from the ground up, but also it can allow a pi in direct control with the main CPU card via interrupts. This logic cannot access the bus directly, it can only load up the registers or FIFO and then issue a manually vectored interrupt back to the main 68K CPU. so the 68K itself has to handle whats going on with the data card, and its logic.
    So even with this, we still need some minimal bootstrap code on the 68K ROM itself to handle whats going on with the data card.
    With the data/control side out of the way, that leaves just the audio part. For the prototype data card, I did not design any of the audio circuitry on the card since I did not quite know yet exactly how to approach it as I wanted to simplify the original audio circuit into a single audio path plus warning alert path. All the extras the system did originally, did not matter here.
    I did wire up the original latch logic they had, but I left them unconnected here.
    So for now, I will forgo the audio circuitry...
  • Analyzing the data card
    techknight • 06/24/2022 at 15:03 • 0 comments
    That leaves the last piece to this puzzle. Now that we have the I/O card, CPU card, and graphics card figured out, that leaves behind the data card.
    The data card serves a few purposes in the machine, it also contains the audio circuitry. it contains the FM demods, the audio switching network, output amplifier and the warning tone generator.
    previously in the project we had already netlisted this board and created a schematic.
    This board is originally designed to demodulate the subcarriers from the satellite transponder.
    Once again, I decide to take a look at the ROM to figure out potentially what is going on with this card, and there is a patent available for the STAR 4000 which explains the data packet format, what all the different types are, and etc. the ROM pretty much follows the patent for the most part.
    Other interesting thing is, there are some stuff in the bottom of the ROM which im not sure what does, but its interesting:
    Some text values there used for something. the Data card has no serial in/out so it must be something that gets sent back to the 68K at some point over the FIFO.
    The architecture of the data card's design, basically has a single byte latch register for the 68K to be able to read, as well as one to be able to write. there is also a FIFO that is read-only by the 68K.
    so therefore, the 68K has two data registers it can read from the data card, and one to write back. There is also two audio registers the 68K can also write to, which can control the audio matrix.
    The other problem is, some of the audio stuff is also controlled by the data CPU. so the two have to work in tandem to control the audio stage. This is painful. THIS... is also why when a 4000 would go into alert mode, the warning tone appeared to have some "breakup"  in it. It is due to the fact the data card's CPU has to go off and do some other stuff handling incoming data which would cause the audio latch to de-assert in short bursts. Even though the 68K is keeping the alert tone enable line asserted during the entire duration.
    The data format at which it uses, they used the old legacy STAR 3000/Jr for text-based products at which the scripts would use and format to display on screen in a graphical manner, you can see this here in ROM with the data parser I had commented:
    So this machine did, in-fact, use the old 37-byte Teletext frame format for controlling its products and parsing the OMCW to determine what is being displayed.
    This coincides with the release of the 4000 being all text based, mimicking the 3000's operation. It was easy for them to do.
    Anyways, a lot of effort would need to be put into conforming to, and formatting the data in a particular way if i were to use this data card.
    Also, we need to build a satellite subcarrier encoder, and an SDLC framer. None of which I felt like doing.
    The satellite no longer exists anymore either.
    I could do what I did with the I/O card, and replace the ROM with my own since it too is also MCS51 based. Trouble is, I would still be stuck with SDLC framing with NRZI-FSK encoding.
    At the end of the day, we really needed to bring the data delivery system into the 21st century to work with our modern standards if we really wanted to use a 1980s machine with 2019 data standards.
    So? I voted for the nuclear option. forgo the entire data card and engineer a new one!
  • I/O Card: Developing new firmware
    techknight • 06/24/2022 at 01:26 • 0 comments
    Since we had a good success with writing a program and running it on the I/O card, we need to start writing the initialization routines for the various hardware bits on that card, as well as writing the protocol for communicating back and forth between it, and the driver on the 68K side.
    The UART took a little bit of trickery. If you look back at the schematic, the baud clock for the UART IC is driven from one of the PIO chip's internal timer.
    We decided to setup the UART to work with 1200 baud. Slow? yes... but it provides a method for getting characters in and out of the 68K system so we will stick with this.
    Initializing the UART:
    And, setting up the initial PIO states and setup to produce the proper baudclock:
    Presto! Now, we need to write some protocol code so I can send commands across the bus back and forth to the UART, an ex:
    Seems pretty simple in concept, doesn't it? It does, however it took a lot of time and iterations/modifications and rewriting the ROM over and over to get this to work correctly. And when I say a lot.. I mean A LOT of trial and error.
    Anyways... that's basically it in a nutshell.
    The mainloop handles all of the commands coming across the bus, it also has a Watchdog reset you must keep happy or the I/O card will keep resetting on you.
    So with that mostly complete, we need to test each part of the firmware as we go along so we dont get caught up in bug hell...
    Testing the UART <-> Bus communication:
    Success!!! We can communicate across the bus from the arduino, to my protocol, and out of the UART.
    So we are well on our way to making functional I/O card firmware
    Next part is to make sure the protocol is working with the 68K's System bus by testing it in an actual system.
    The trouble is, we have not written any 68K code at all yet. So quickly, I grabbed a copy of VASM and made a simple little ROM that keeps the watchdog happy on the CPU card, and then i sent a random LED set byte across the bus over to the I/O card and then loop forever. a very simple "hello world" program on the 68K side:
    perfect! We knocked two birds out with one stone here. one, we confirmed the 68K can communicate with my firmware on the I/O card, and then the 68K CPU itself can run a "Hello World" ASM program assembled with VASM and send a byte out to the I/O card.
    I know, I jumped way ahead here but i needed to demonstrate the functionality of the IO card.
    Next up... the data card.
  • I/O Card: A silver lining?
    techknight • 06/24/2022 at 00:50 • 0 comments
    Given the original ROM is a dumpster fire to me, trying to write a driver to run that from the 68K side is going to be a nightmare since we do not have the original codebase that used this card, that was downloaded from the satellite and embedded into the binary.
    So to save what little sanity I had left, I need to look at custom ROM development for the 8051 with this particular card.
    Prior to this point, I have never written MCS51 assembly before! We are going to need to find a toolchain, and learn the assembly language so we can do something with it. Luckily the assembly language is fairly similar to any other 8 bit microcontroller of the era, so it wasnt hard to pick up.
    But.... before we can do anything, we need to prep the hardware so we can shove some bytes back and forth into the card to test operations.
    I did try the brute-force method with the original ROMs with poor results.
    Yep. This one was just as crazy as the graphics card.
    I am going things this way to eliminate every potential variable I can, up to this point I have not touched the 68K architecture at all, nor written a hello world program to download and run on the 68K system itself.
    Using an arduino as the "CPU" in place of the 68K makes this task much easier when I need to hack on and work with a specific piece of hardware, as I did with the graphics card.
    The next piece of the puzzle, I need a toolchain for the MCS51. I did some searching around and the ONLY thing I could find was Keil. Keil is a paid product sadly so I had to deal with this situation. I dont know of any open-source assemblers for the MCS51 either, So I stuck with Keil.
    We need to start the skeleton of the ROM code, such as defining port pins and where they are going to go:
    Since the INT0 and INT1 routines from the original ROM are fairly simple and timing critical, we shall borrow those for the new ROM project as I think that would be the easiest:
    Now, when writing a new firmware for a completely foreign card that you wish to do your own thing with, you have to start thinking about the protocol you are going to use in which your driver will be written to communicate with the card.
    With that in mind, you can see my commented code/lines in the original INT handlers for bus communications where I tried to do some special things my own way for my own protocol adaptation.
    Unfortunately, no matter how hard I tried, anything i added/took away here would break the bus timing and prevent the 68K from reading/writing legible bytes from the I/O card.
    so this interrupt absolutely COULD NOT be messed with in any way, it was timing critical! So I left these routines bland for the most part, all they do is read/write into the external SRAM in each PIO chip. C0XXX writes the first chip, C4XXXX writes the 2nd chip. From this point, it is up to me to detect byte changes in that chip in the mainloop and handle whats going on, change those bytes, and raise an interrupt back to the 68K CPU to service what I just did.
    But, before we get so carried away with making a protocol, writing the control logic for the RS232 UART, GPIO, LEDs, etc... how about a simple hello world ROM?
    why, of course! the best way to test this card standalone imho to make sure the ROM I am writing is working properly is to attempt to initialize the PIO hardware, and do some blinkenLEDS:
    Success!!!! We able to write code, and assemble it. Burn it onto a ROM, and run the board. :-)
    At this point? we need to start looking at initializing all the peripherals on the card, and then writing a protocol to communicate with all of this from the 68K side.
    Now, time to move onto developing the ROM for this card!
  • I/O Card: Trouble in paradise
    techknight • 06/23/2022 at 23:50 • 0 comments
    After completing the schematic and architecture of the I/O card, It is time to take a look at the ROM.
    With how unique the bus interface logic is back to the 68K, essentially using a PIO and a few other things to mesh with the 68K read/write cycles from the MCS51, I just had to take a look at the routines and document how they pulled this off.
    A quick study of the bus interface logic, reveals a PAL which acts as an address decoder. This address decoder is tied to INT0 and INT1 of the CPU:
    This helps aid in finding where those routines are in ROM. Digging through ROM, I was able to locate the routines:
    The above subroutine is INT1, which is decoded at the address space I had commented in the above code. It is a fairly clever subroutine!
    I commented all of the ASM code to better understand what is going on with the above subroutine. It may not be 100% accurate, but its as close as I can get it.
    The INT0 routine is a bit longer, as its doing some other stuff.
    As we can see, the C0XXXX code is much larger, and it has additional checks in it. I am going to assume at this point, this is where the commands to actually control the card are sent. whereas the INT1 handler might just be for data only. But your guess would be about as bad as mine.
    At this point, we have somewhere to start at least. Since INT0/INT1 are the only way the 68K can speak to this card, we can assume the command processor has to be triggered from this as well. you can see where it reads 4 bytes into 0x14-0x17 in the CPU's RAM space. So we must find the routine that handles all of this outside of the interrupt in order to learn how to control this card in the method they proposed.
    So to help try and find this, Lets take a look at the RESET vector:
    As you can see with the above, we have basic initialization code for the registers and RAM, a call to a code block at 2047, and then a branch always loop at code_52. so it just sits there indefinitely.
    That clues us in that this device is entirely interrupt driven. Now, bear in mind this device also has to run a modem, AT keyboard, and a host of other things.
    But the problem begins with the code block at 2047. its literally a nightmare scenario, and its super hard to follow as it goes through.
    If we take a look at the timer interrupt, we have this:
    And that's it, all it does. Appears to be settings/clearing flags and changing some things in RAM, however I do not know precisely what its actually doing. It might be related to the modem or AT keyboard. since they are using the same UART on the CPU for both the modem, and the AT keyboard it could be related to both. Who knows...
    However, with all of that said I fail to see how it catches and processes data from the bus. this code is super hard to follow. For example, that code block called from RESET just goes on and on and on forever:
    So instead of spending days and days and days trying to chase this code since theres no examples on how to use the API of this ROM, I had to make a decision to abandon the ROM entirely and just write my own thing to save grace here, I could also avoid writing the routines for the modem, and AT keyboard since I did not need either of them. I only wanted the LEDs, the RS232 port, and general purpose I/O.
    The main code block are literally ljmp ops all over the place, back and forth. they arnt using any rts or jsrs, its the epitome of spaghetti code...
    Hence, trouble in paradise...
  • Analysis: The I/O Card
    techknight • 06/23/2022 at 01:36 • 0 comments
    Up to this point, we have only focused on the basic architecture of the system and went into detail on the graphics card, and CPU card, only briefly mentioning the data and I/O cards.
    But before we can begin to get a hello world program on the system, we must take a closer look at the I/O card.
    In a previous blog post, we mentioned the schematic of the I/O card, however to keep things simple, we will post the schematic again here:
    With that, here is the system architecture of said card:
    Peripheral - I/O Card
    8051 Memory Map:
    $0000 - $01FF = RAM
    $0200 	      = UART Data
    $0201         = UART Command
    $8000         = PIO1 Command/Status Register
    $8001         = PIO1 PORTA (VME Address/Data AD1-AD8)
    $8002         = PIO1 PORTB (Rear External Switches 1-8)
    $8003         = PIO1 PORTC (Various)
    $8004         = PIO1 TCNT0 Low
    $8005         = PIO1 TCNT0 High
    $8100         = PIO2 Command/Status Register
    $8101         = PIO2 PORTA (Indicator LEDs)
    $8102         = PIO2 PORTB (DTMF Dialer Codes, 1 Indicator LED)
    $8103         = PIO2 PORTC (Bus Clear, Charging Indicator)
    $8104         = PIO2 TCNT0 Low
    $8105         = PIO2 TCNT0 High
    I/O Card VME Addressing:
    $C00000 to $C001FF = 8051 INT0
    $C04000 to $C041FF = 8051 INT1
    PIO-1:
    PA0: VME Address/Data 0
    PA1: VME Address/Data 1
    PA2: VME Address/Data 2
    PA3: VME Address/Data 3
    PA4: VME Address/Data 4
    PA5: VME Address/Data 5
    PA6: VME Address/Data 6
    PA7: VME Address/Data 7
    PB0: Switch 1
    PB1: Switch 2
    PB2: Switch 3
    PB3: Switch 4
    PB4: Switch 5
    PB5: Switch 6
    PB6: Switch 7
    PB7: Switch 8
    PC0: (LED 7) Modem In Use LED
    PC1: Modem ALB
    PC2: Modem SQT
    PC3: Modem/AT Serial Select
    PC4: Cube Relay Control
    PC5: VME IRQ2
    PIO-2:
    PA0: (LED 10) System Error LED
    PA1: (LED 8) Spare LED
    PA2: (LED 2) Sat Data LED
    PA3: (LED 3) Local Video LED
    PA4: (LED 6) On Air LED
    PA5: (LED 4) Spare LED
    PA6: (LED 1) Satellite Video LED
    PA7: (LED 5) Pre-Roll LED
    PB0: DTMF Keypad Column 1
    PB1: DTMF Keypad Column 2
    PB2: DTMF Keypad Column 3
    PB3: DTMF Keypad Row 1
    PB4: DTMF Keypad Row 2
    PB5: DTMF Keypad Row 3
    PB6: DTMF Keypad Row 4
    PB7: (LED 9) Spare LED
    PC0: VME IACK2
    PC1: Battery Charging Indicator
    PC2 - PC5 unused.
    This is basically where everything is hooked up as far as the address map. Essentially, it is an 8051 based card, with two PIO/RAM ICs, and a UART IC.
    The card handles the LEDs, a modem, AT keyboard, serial port, and some general purpose I/O.
    The funny thing about this card however, is the 68K bus interface logic and timing. It is all software-based and its controlled via interrupt on the 8051, so the interrupt execution time has to be in-step with the 68K Bus Cycles. absolutely insane, and there is NO room for timing variances or error on the bus read/write interrupt handlers or errors will ensue. I tried it.
    One thing i noticed right away on the design of this particular card, is how there is an inverter off of the Q output on the flipflop, instead of just using the /Q output. As seen here:
    This part made no sense to me. You would save a gate if you just wired the /Q output instead of using a makeshift inverter. Maybe there is a timing reason? Honestly, I do not know.
    In the next part, we need to disassemble the ROM and take a look at what is going on, since we have no driver or any details on how to drive this card.
  • Animation
    techknight • 06/23/2022 at 00:44 • 0 comments
    Now up to this point we have the graphics card pretty much figured out. We have the framebuffer control on its fundamental levels where we can set palettes and viewports and their resolutions.
    The next part of this puzzle though is how do we achieve animation? the weather icons used on the WS4000 had an animation to them where you can see the rain falling, such as:
    How do we achieve this effect on the WS4000, and how did they do this originally?
    Well, they use palette swapping trickery. Thing is, you can upload a palette to the RAMDAC as we explained in an earlier post, and you can rotate colors around on the index to do this.
    BUT. the WS4000 actually offers a method to do this on its own, which is identified by this function from ROM that I had documented here:
    code:00000776 CHECK_FOR_ANIMATE:                      ; CODE XREF: code:0000111Cp
    code:00000776                                         ; code:0000113Fp ...
    code:00000776                 mov     A, RAM_39
    code:00000778                 jz      code_782
    code:0000077A                 mov     DPTR, #0x601
    code:0000077D                 clr     A
    code:0000077E                 movx    @DPTR, A
    code:0000077F                 lcall   Animate_Palette
    code:00000782
    code:00000782 code_782:                               ; CODE XREF: CHECK_FOR_ANIMATE+2j
    code:00000782                 lcall   code_734
    code:00000785                 ret
    code:00000785 ; End of function CHECK_FOR_ANIMATE
    code:00000785
    code:00000786
    code:00000786 ; =============== S U B R O U T I N E =======================================
    code:00000786
    code:00000786
    code:00000786 Animate_Palette:                        ; CODE XREF: CHECK_FOR_ANIMATE+9p
    code:00000786                                         ; Animate_Palettej ...
    code:00000786                 jb      RAM_20.3, Animate_Palette ; Wait for previous operations to clear
    code:00000789                 mov     R7, RAM_39      ; How many color blocks to copy
    code:0000078B                 mov     R0, #0x35 ; '5' ; Beginning location for RAMDAC Palette Addresses
    code:0000078D
    code:0000078D code_78D:                               ; CODE XREF: Animate_Palette+4Ej
    code:0000078D                 mov     DPTR, #0x601    ; Location Pointer to Palette Table
    code:00000790                 movx    A, @DPTR
    code:00000791                 mov     R1, A           ; Store Value at RAM 0x0601 into R1
    code:00000792                 mov     A, @R0
    code:00000793                 mov     P2, #0x80 ; 'Ç' ; Set Palette Write Address
    code:00000796                 movx    @R0, A          ; Store Value in I-RAM 0x35 as RAMDAC Palette Address
    code:00000797                 mov     P2, #0x88 ; 'ê' ; Set RAMDAC to Palette Memory
    code:0000079A                 mov     A, #7
    code:0000079C                 clr     C
    code:0000079D                 subb    A, R1           ; Subtract 7 from the contents in 0x0601
    code:0000079E                 mov     R2, A           ; Store Result into R2
    code:0000079F                 mov     A, @R0          ; Read Palette Address from I-RAM 0x35
    code:000007A0                 add     A, R1           ; Add Current 0x0601 Value to RAMDAC Palette Address
    code:000007A1                 mov     B, #3           ; B Register
    code:000007A4                 mul     AB              ; Multiply Added Palette Address with 3. A contains Low byte, B contains High Byte Result
    code:000007A5                 mov     DPL, A          ; Data Pointer, Low Byte
    code:000007A7                 mov     A, B            ; B Register
    code:000007A9                 add     A, #0           ; Store 16-bit Multiply Result into Data Pointer.
    code:000007AB                 mov     DPH, A          ; Data Pointer, High Byte
    code:000007AD
    code:000007AD code_7AD:                               ; CODE XREF: Animate_Palette+30j
    code:000007AD                 movx    A, @DPTR        ; Read Red Value from RAM @DPTR
    code:000007AE                 inc     DPTR            ; Advance to Next Value (Green)
    code:000007AF                 movx    @R0, A          ; Write Red Value to RAMDAC Palette
    code:000007B0                 movx    A, @DPTR        ; Read Green Value from RAM @DPTR
    code:000007B1                 inc     DPTR            ; Advance to Next Value (Blue)
    code:000007B2                 movx    @R0, A          ; Write Green into RAMDAC Palette
    code:000007B3                 movx    A, @DPTR        ; Read Blue Value from RAM @DPTR
    code:000007B4                 inc     DPTR            ; Advance to Next Value (Red)
    code:000007B5                 movx    @R0, A          ; Write Blue into RAMDAC Palette
    code:000007B6                 djnz    R2, code_7AD    ; Decrement R2, Repeat Palette Write until 0
    code:000007B8                 mov     A, R1
    code:000007B9                 jz      code_7D3
    code:000007BB                 mov     A, @R0
    code:000007BC                 mov     B, #3           ; B Register
    code:000007BF                 mul     AB
    code:000007C0                 mov     DPL, A          ; Data Pointer, Low Byte
    code:000007C2                 mov     A, B            ; B Register
    code:000007C4                 add     A, #0
    code:000007C6                 mov     DPH, A          ; Data Pointer, High Byte
    code:000007C8
    code:000007C8 code_7C8:                               ; CODE XREF: Animate_Palette+4Bj
    code:000007C8                 movx    A, @DPTR
    code:000007C9                 inc     DPTR
    code:000007CA                 movx    @R0, A
    code:000007CB movx A, @DPTR...
View all 31 project logs
Radeon64 wrote 10/26/2023 at 08:05 • point
nice :]
Benjamin Federico wrote 06/25/2023 at 19:36 • point
may I suggest you turn the schematic images into actual schematic files, preferably the Gerber file format (.gbr) this way I could upload them to PCBway and have them create recreated WS4000 boards, so I could make my own software (or possibly you could upload the recreated WS4000 software, and information on how to send data to it?)
N.S. wrote 10/09/2022 at 05:45 • point
Wow! Reading all of these logs are incredible! I've never seen a reverse engineering this in depth before
techknight wrote 05/25/2023 at 20:13 • point
Thanks for reading! it was a ton of effort purely motivated by childhood nostalgia.
Frank Smith wrote 03/18/2021 at 23:32 • point
you may want to reach out to Doug Pincock who was involved in the development of the Weather Star: http://www.pincock.ca/?page_id=5179&dir=Amirix. One of the links on this page is about the WS.
techknight wrote 03/19/2021 at 00:00 • point
Thanks for the tip! its been so many years, I doubt he would remember a whole lot of fine detail. Plus, I doubt he works at Amirix anymore. But I sent an email just out of curiosity!
freefuel wrote 03/15/2021 at 19:17 • point
rather than implementing the system in MAME perhaps consider the MiSTer FPGA project? https://misterfpga.org/
techknight wrote 03/15/2021 at 19:25 • point
I don't know enough about FPGA design to do such thing. Plus someone would need to finish what I started with trying to reverse engineer the XC2018 FPGA bitstream into proper logic blocks, so it could be ported to another FPGA arch.
freefuel wrote 03/15/2021 at 19:44 • point
may I suggest you post your project up there anyway, you might find some people who know more about the system.  I also suggest you reach out to anyone you can contact here, https://infoage.org/events/ who knows you might find some of the original developers.
Mike Szczys wrote 03/15/2021 at 15:44 • point
That is just so cool! Kudos on making this one happen :-D
techknight wrote 03/15/2021 at 16:20 • point
Not a problem! I still have a bunch more project log entries to post. including that of probing the graphics card afterwords.
Darren wrote 03/15/2021 at 05:14 • point
The MAME project has a utility for turning PAL dumps into logic called jedutil.  It looks like it also handles registered logic.
techknight wrote 03/15/2021 at 11:46 • point
I am not 100% familiar with MAME, so I didn't know that. I did get in touch with a MAME developer long ago about writing a WS4000 driver for MAME. It is partially complete, but it isn't 100%. I abandoned that avenue and just wrote the software and debugging on the machine itself. But I will discuss this later in the series.
Dan Maloney wrote 03/08/2021 at 19:50 • point
Sounds like a fun journey. Waiting eagerly for updates.
techknight wrote 03/08/2021 at 22:33 • point
Oh definitely! Lots of juicy content coming, little by little. This has occured over the last 2 years (Still occuring) and just thought to do a project blog here. so its gonna take some time. :-)
