- 68008 CPU
- 32 bit internals (registers, etc)
- 20-bit address bus (1 MB space)
- 8-bit address bus
- 8 or 10 MHz clock
- 512KB SRAM
- Can also use 128KB SRAM part
- Up to 448KB EPROM
- Jumpers for 28, 32 pin parts
- 68681 Dual UART
- (2) 6-pin FTDI connectors
- Up to 38,400 baud
- 6-bits of output
- 4-bits of input
- Reset switch and 5V power monitor
- Two 16V8 PLDs to make configurations easier
- 5V Power header
- 2x4, 0..1" pitch connector
- 95mm x 95mm (matches other Land Boards cards)
land-boards.com
lucio
techknight
Keith
