First Person Shooter Game
08/12/2024 at 15:55 • 0 commentsTechnical
- C Code
- Runs on ANSI terminal
- Load S records using S68K_02 monitor or S68K_002 plus Enhanced BASIC using 'L' command
- Run at 0x2000 with R2000 command
Gameplay
- First person shooter
- Target '@' moves around randomly
- Bullet is '-'
- Can only have one bullet flying at a time
- Animated hit
Controls
- Move around the shooter '}' with arrow keys
- Shoot using the SPACE bar
- Q to quit.
Status Bar
- Command help message
- Counts hits and misses
- Timer running
Monitor updates plus Enhanced BASIC
08/06/2024 at 22:39 • 0 commentsGot the monitor running on the card and added a couple of functions:
- S record loader
- Timer
Software that runs on the card:
- S68K_02 Monitor code
- Enhanced BASIC running from SRAM
- S68K_02 monitor plus Enhanced BASIC (in ROM)
- figForth
Using gcc toolchain and wrote quite a few little pieces of software
- nncurses - ANSI terminal driver that isn't ncurses
- Some simple games
Working on Monitor Code
06/27/2024 at 19:26 • 0 commentsStarting from Hayden Kroepfl's 68k Homebrew ROM Monitor code. Used his 68680 DUART code to get card working.
Did my own RAM test code that tests data and address lines better and quicker.
Examine works. Help works. Deposit works.
Run coded (not tested yet).
My code is here.
Serial Port Wiring Issue
06/26/2024 at 19:33 • 0 commentsMiswired serial connections (TXB, RXA).
Can be fixed by wiring connections on H1.
Fixed via cuts/jumpers.
Works.
10 MHZ Crystal Oscillator
06/26/2024 at 14:29 • 0 commentsInitially ran card with 8 MHz crystal can oscillator. 10 MHz oscillators were not in stock at Mouser.
Ordered 10 MHz can oscillator and tested card. Worked good.
Timing Analysis via Measurement and Datasheet
Timing measurements with 8 MHz crystal oscillator showed very wide clock pulses on DS*, etc. Modern SRAM is 55 nS and modern Flash is 70 nS so the only wait states on the card can come from the DUART and it provides its own DTACK*.
Project Status
06/24/2024 at 23:20 • 0 commentsCard is running simple example code with these features
- SRAM Tests (data and address lines verified)
- Code running out of EPROM
- DUART sending out data
- Blinking LED on O2 output pin on the DUART
- PLDs working
- 8 MHz oscillator (ordered 10 MHz part)
Code is in GitHub here.
land-boards.com
