Simple-68008 CPU Card
About as basic as a card can get
Public Chat
68008 CPU card
  • 68008 CPU
    • 32 bit internals (registers, etc)
    • 20-bit address bus (1 MB space)
    • 8-bit address bus
    • 8 or 10 MHz clock
  • 512KB SRAM
    • Can also use 128KB SRAM part
  • Up to 448KB EPROM
    • Jumpers for 28, 32 pin parts
  • 68681 Dual UART
    • (2) 6-pin FTDI connectors
    • Up to 38,400 baud
    • 6-bits of output
    • 4-bits of input
  • Reset switch and 5V power monitor
  • Two 16V8 PLDs to make configurations easier
  • 5V Power header
    • 2x4, 0..1" pitch connector
  • 95mm x 95mm (matches other Land Boards cards)
View all 6 project logs
Rich text editor
