test-relay.py
Completely optional script I used to test my 8 channel relay when it was hooked up. It just turns them all on one at a time then all off one at a time
plain -
2.54 kB -
03/18/2021 at 05:00
Download
run.py
Main File to run the Twitch checking while loop
plain -
3.92 kB -
03/18/2021 at 04:42
Download
config.py
Config file
plain -
1.63 kB -
03/18/2021 at 04:42
Download
helper.py
Extra functions including Twitch APIs and Relay controls
plain -
11.87 kB -
03/18/2021 at 04:42
Download
Bottom Base.stl
Bottom Base Cap for 3D Printing
Standard Tesselated Geometry -
98.32 kB -
03/18/2021 at 04:39
Download
Top Base.stl
Top Base Cap for 3D Printing
98.32 kB -
03/18/2021 at 04:39
Download
Back Cover Export.dxf
Rear cover to be cut in 3mm (preferably not clear) acrylic
AutoCAD DXF -
3.71 kB -
03/18/2021 at 04:39
Download
Inner Shelf Export.dxf
Inner shelf for electronics mounting to be cut in 3mm acrylic
AutoCAD DXF -
5.17 kB -
03/18/2021 at 04:39
Download
Rear Cover Export.dxf
Back Cover (where the ports of the pi are) to be cut in 3mm acrylic and then labelled to identify the OTG and PWR USB ports on a Pi Zero easily
AutoCAD DXF -
6.05 kB -
03/18/2021 at 04:39
Download
Top Cover Export.dxf
The 'front' or clear side of the relay case to be cut in 3mm acrylic. A logo can also be etched onto this side
AutoCAD DXF -
7.65 kB -
03/18/2021 at 04:39
Download
