Slitherbot
A Snake robot with 3D printed skin actuated by micro-servos
Slitherbot = Snake vertebrae, ribs, head and tail modeled in CAD + 3D printed skin + Actuation using micro servos + Software to inject motion
To be honest, I find the snakes a bit creepy. But their gait is very graceful and attractive.
Robots modeled after snakes have been around for quite some time. The earliest literature I could find on Robot snakes was a 1976 paper by Hirose and Umetami in which they discuss the biological principle of lateral inhibition used for controlling the Active Chord Mechanism (ACM) with tactile sensors. Since then, there has been a lot of research in characterizing the movement of the snakes and lot of DIY attempts to imitate that.
There are mainly 4 kind of gaits that have been identified in snakes - serpentine, sidewinding, rectilinear and concertina. Serpentine is known to be very common and is what I have attempted in this project. My main goal with the project was to make the snake robot more accessible (low cost) by using inexpensive off-the-shelf parts.
Guts
I started by reviewing the skeletal structure of a snake. Using that as a starting point, I designed one of the ribs in Fusion 360. After a couple of iterations, I settled on the following design as it seemed to work well in both form and function.
  • It was modular and so could be easily extended to achieve the desired length of the snake.
  • The outer contour was smooth to allow for installation of an artificial skin.
  • It was light in weight which would allow its actuation to be easily handled by a micro servo.
Locomotion
For snake locomotion, I decided to stick with the use of passive wheels as the mechanism is simple and effective. The wheels were 3D printed and the axle was simply an M2 screw turning inside an M3 sleeve to minimize the cost.
A 16 servo controller I had came in quite handy. It meant that I could attach 16 MG90S motors and make the size of the snake a bit more life like. From head to its tail, the slitherbot measures more than 1 meter (~ 1134mm).
With all the links connected as shown, I was able to get the desired motion by simply passing a cosine wave through the robot's body. One can also varied the wave's amplitude to give a more natural feel to the slither. I also added support for obstacle detection using an infrared sensor.
Skin
To make it a bit more realistic, I decided to give a skin to the robot. I started by modelling the skin in CAD but after several iterations and trying out different materials, I was not getting anywhere. The problem was that after putting any kind of covering, the micro servo's were restricted enough to not produce the serpentine motion I was looking for. I have listed some of my unsuccessful attempts later in the blog to document them.
Finally, I stumbled upon the following research, Mechanical Characterization of Structured Sheet Materials by Disney Research. The paper proposes a comprehensive approach to characterizing the mechanical properties of structured sheet materials. Two-dimensional linear materials can be classified into four symmetry groups:
  • Anisotropic
  • Orthotropic
  • Tetragonal
  • Isotropic
The various material symmetries lead to characteristic Young’s modulus profiles and can be related to the structural symmetries of the underlying tiling.
For the slitherbot, the Young's module profile of the orthotropic group looked fairly promising. The research team has put together a nice interface at http://structuredsheets.com/. Based on my requirements and the suggested options, I decided to go with the following pattern for the skin design.
I then modeled the design in Fusion 360 and printed it using TPU. The result was really amazing. It worked exactly as the research outlines.
Design Choices
  • To improve traction of the wheels, I put a small rubber band around each of the wheels.
  • Routing the cables from the servo motors need some planning since we are not using serial servos ($$). To reduce the number of wires coming to the electronics housing, I ran a voltage and ground rail through the entire length of the snake so that the...
connections.fzz
Wiring diagram for Slitherbot
fzz - 52.38 kB - 03/31/2021 at 17:31
Download
  • 1
    3D printed parts and electronic components
    Here is the list:
    • Snake head consisting of a top and a bottom half that snap together. It houses the infrared sensor for proximity detection.
    • Mid section or the body. It consists of a series of individual elements or the 'ribs'. Each rib is connected to the next through a vertebrae section integrated into the printed part.
    • The belly portion enclosed within each rib is used to house the motor for locomotion.
    • Each rib is actuated by a micro servo motor using 2 wheels attached on either side.
    • The space between the wheels is slotted to carry the wires for power, ground and PWM signal to the motors and the infrared sensor.
    • The caboose is used to house the rest of the electronics including:
      • Arduino Nano as the microcontroller to run the code for locomotion and proximity detection.
      • A 16-Channel 12-bit PWM/Servo driver, PCA9685 to driver the 16 servos over I2C.
      • An MP1584EN DC-DC Buck Converter to provide 5V to the servo driver.
    • A 2S lipo battery to power the entire robot.
    All parts except the skin were printed in PLA with 0.28 mm layer height and a 0.4 mm nozzle on an Ender 3. The skin was printed in TPU.
    The STL files can be found on Thingiverse.
    Click on the github link for the software.
  • 2
    Assemble the head
    • Install the infrared proximity sensor on the bottom half of the head.
    • Snap the 2 halves together.
  • 3
    Assemble the body
    • The body is a collection of ribs connected together through the vertebra using a coupler.
    • Assemble the rib section as shown in the video.
View all 6 instructions
Bob Found wrote 02/01/2024 at 16:09 • point
I used Tinkercad to make the base under the servo bracket about 3-4 mm thicker so the bracket now rotates in the bottom part.  I also made the cable carrier part of the rib so I don't need screws to connect.  The wheels shown on this site are thicker than the ones provided at Thingiverse.   There is not much info on how to connect the ribs together.  The holes on both pieces are about 3mm, and thanks to filament shrinkage are a little smaller so they might self-thread.  I would use brass screw inserts instead to ensure the ribs stay connected.
Bob Found wrote 01/28/2024 at 19:02 • point
A part on Thingiverse is different than the one shown here.  On this site, the wire guide at the bottom of the rib is all part of the rib, one piece.  On Thingyverse it is two pieces requiring two screws possibly with threaded inserts.  I only made on complete assembly and the servo bracket does not go down far enough to engage the hole and axle.  The servo has nothing to "swivel" on.  Any updates to this project?
