Arduino.ino
04/02/2021 at 07:56 • 0 comments//code of Universal Internet Connected Remote Control // idea form maker.io //made by RVS Aditya From HackAtech Industries #include <IRremoteESP8266.h> #include <IRsend.h> #include <ESP8266WiFi.h> #define LED_PIN 5 #define STORAGE_SIZE 5 const char* ssid = "YOUR_NETWORK_NAME"; const char* pass = "NETWORK_PASSWORD"; WiFiServer server(80); IRsend sender(LED_PIN); long codes[STORAGE_SIZE] = {0x00123,0x02,0xAB,0x0F,0x0}; bool stored[STORAGE_SIZE] = {true,false,false,false,false}; int protocols[STORAGE_SIZE] = {0,1,1,0,1}; // Function Prototypes int containsValidIndex(String); String findParameterValue(String, String); void setup() { Serial.begin(9600); while(!Serial) delay(50); sender.begin(); Serial.println(""); Serial.print("Connecting to "); Serial.print(ssid); WiFi.begin(ssid, pass); while(WiFi.status() != WL_CONNECTED) { Serial.print("."); delay(500); } Serial.println("Done!"); Serial.println("Starting server..."); server.begin(); Serial.print("Server started with address "); Serial.print("http://"); Serial.print(WiFi.localIP()); Serial.println("/"); } void loop() { // Check for incoming connections WiFiClient c = server.available(); if(c) { while(!c.available()) delay(10); // Read the first line of the HTTP request // It contains something similar to the following line: // METHOD /requested_url HTTP_VERSION // for example: // GET /send?value=0x0085&protocol=NEC HTTP/1.1 // However, for the sake of simplicity this device only accepts // GET requests as they can be sent with any web browser. // Updating values this way is not the 'correct' way according to // the HTTP standard but it makes using the device easier. String request = c.readStringUntil('\r'); c.flush(); int error = 0; int value = request.indexOf("value="); int protocol = request.indexOf("protocol="); int index = request.indexOf("index="); int snd = request.indexOf("/send"); int str = request.indexOf("/store"); int del = request.indexOf("/delete"); Serial.println(request); // The following few if/else-statements parse the incoming request // and then execute the action that the user requested. // The user requested the send page and did not include /store or /delete in their request if (snd != -1 && str == -1 && del == -1) { // The user requested the send page and included a value for the index if(index != -1) { // Check if the supplied index is valid (i.e. at least zero and less than STORAGE_SIZE) // And check if the values array contains an entry at the requested position // First, get the value of the parameter as a string String index_string = findParameterValue(request, "index"); // Next, convert it to an integer and check whether the value is valid int i = containsValidIndex(index_string); if(i > -1 && stored[i]) { // The parameter was valid. Repeat the stored value! // Make sure to verify the bit length for your remotes! // I used 32 and 14 in this program, but yours might vary if(protocols[i] == 0) sender.sendNEC(codes[i], 32); else sender.sendRC5(codes[i], 14); Serial.print("Repeat the value stored at position "); Serial.println(i); } } // The user supplied the wrong parameters for this request. else { error = 1; Serial.print("Unknown request: "); Serial.println(request); } } // The user requested the /store page and the request didn't include // the /send or /delete page else if(str != -1 && snd == -1 && del == -1) { // The user supplied the wrong parameters for this request. // (Either of the three parameters is missing) if(index == -1 || protocol == -1 || value == -1) { error = 1; Serial.print("BAD REQUEST. Missing field: "); Serial.println(request); } else { String p = findParameterValue(request, "protocol"); String v = findParameterValue(request, "value"); int i = containsValidIndex(findParameterValue(request, "index")); // Check if the supplied index is valid if(i > -1) { Serial.print("Store "); Serial.print(v); Serial.print(" for protocol "); Serial.print(p); Serial.print(" on position "); Serial.println(i); codes[i] = strtol(v.c_str(), NULL, 16); protocols[i] = (p == "NEC") ? 0 : 1; stored[i] = true; } } } // The user requested the /delete page and the request didn't include // the /send or /delete page else if(del != -1 && str == -1 && snd == -1) { // The /delete page requires the index to work. It ignores the other parameters. // So if the request didn't include the index, then answer with an error if(index == -1) { error = 1; Serial.print("BAD REQUEST. Missing field: "); Serial.println(request); } else { int i = containsValidIndex(findParameterValue(request, "index")); if(i > -1 && stored[i]) { stored[i] = false; Serial.print("Delete the value stored on position "); Serial.println(i); } } } // Return the response // If no error occurred, send an HTML page that lists the stored codes // and that contains two forms for managing them (add new ones and delete existing codes). if(error == 0) { /* HTML code omitted! */ } else { // Return a response header /* HTML error response omitted! */ } } } int containsValidIndex(String index_string) { // First check whether the string only contains digits for(int i = 0; i < index_string.length(); i++) { if(!isDigit(index_string.charAt(i))) return -1; } // Then convert the string to an int and repeat the stored valud at that // position in the array (if the index is valid) int index_num = index_string.toInt(); if(index_num >= 0 && index_num < STORAGE_SIZE) return index_num; else return -1; } String findParameterValue(String request, String param_name) { int param_name_length = param_name.length()+1; // First, dispose of everything in the request that comes prior to the index parameter String tmp = request.substring(request.indexOf(param_name)); // Then check whether the remaining part of the request (everything that comes after // the request=... part of the URL) contains more paramters (they are separated by // ampersand characters (&)). if(tmp.indexOf("&") != -1) // If there are more parameters, the value of the index sits between the // parameter name (index=) and the next ampersand (&). // For example: URL?index=5&other_param=24 (...) return tmp.substring(param_name_length, tmp.indexOf("&")); else // Otherwise, the value of interest comes right before the next // whitespace character like this: // URL?index=5 HTTP(...) return tmp.substring(param_name_length, tmp.indexOf(" ")); } //project made by R.V.S.Aditya From HackAtech Industrieswritten in Arduino editor by RVS Aditya
