1Converting accelerometer data to tap codes
If you use Robotics Cape or Beaglebone Blue board like I do, Robot Control library supports tap detection out of the box. You can look for example at my code: https://github.com/kikaitachi/naminukas-brain/blob/main/src/HardwareBeagleBoneBlue.cpp#L74
Mykolas Juraitis
