Prototype 2
04/18/2021 at 13:45 • 0 commentsPrototype 2 improved on Prototype 1 by decreasing the screen angle from 45° to 22.5°. I had some initial problems with getting the Optics to work correctly, but with a 1.5x lens it worked fine with only minor image warp.
No lens, longer distance from screen ![]()
No lens, short distance from screen ![]()
2.5x lens, long distance from screen ![]()
2.5x lens, short distance from screen ![]()
1.5x lens, long distance from screen ![]()
1.5x lens, short distance from screen The next steps for the Hardware are to reduce the weight of Project GLASSES, correct the remaining image distortions by switching to a fresnel lens and putting it at an angle, making a frame to wear it and use it, and mounting an MPU9250 to make things like a virtual horizon possible.
Prototype 1!
04/18/2021 at 13:37 • 0 commentsPrototype 1 has been done for a while, though the projection screen was at a 45° angle, which was suboptimal and would get in the way easily. Also, the screen holder had a 2mm slot, and the sheet of acrylic I use is 1mm thick, because I originally planned on using a 2mm acrylic sheet, but I found a cheaper 1mm sheet on AliExpress.
![Prototype 1 Prototype 1]()
Prototype 1, attached to a set of cinema 3d glasses for testing.
OmegaRogue
