BioAmp EXG Pill v1.0b
BioPotential amplification on your finger tip!
Public Chat
Starting from
$69.00
lorkhatri has 334 orders / 2reviews
Ships from India
BioAmp EXG Pill is a small, powerful Analog Front End (AFE) biopotential signal-acquisition board that can be paired with any 5 V microcontroller unit (MCU) that has an analog-to-digital converter (ADC), such as an Arduino UNO, an Arduino Nano, or an ESP32 (voltage-divider), among others. It also works with any dedicated 5 V (input range) ADC like the Texas Instruments ADS1115 or ADS131M0x, among others.
BioAmp EXG Pill is capable of recording publication-quality biopotential signals like ECG, EMG, EOG, and EEG, without the inclusion of any dedicated hardware or software filters. Its small size allows easy integration into mobile and space-constrained projects, and its powerful noise rejection makes it usable even when the device is close to the AC mains supply. Any 1.5 mm diameter wire can be used as a strain-relieving electrode cable, making BioAmp EXG Pill very cost-effective in comparison to other options.
BioAmp EXG Pill can be used for projects like,
  1. AI-assisted congestive heart failure detection using CNN (ECG).
  2. Heart Rate Variability calculation for heart ailments detection (ECG).
  3. Prosthetic arm (servo) controller (EMG).
  4. Palsy physical therapy quantitative analysis device (EMG).
  5. Real-time game controller (EOG).
  6. Controlling LED with Brain waves (EEG).
  7. Patient monitoring device.
The BioAmp EXG Pill can be used in a variety of ways, the YouTube video below shows a potential way of using v0.7 of BioAmp EXG Pill.
A lot has improved in terms of interference rejection and flexibility of using BioAmp EXG Pill from v0.7 to v1.0 and the YouTube video below shows the ECG, EMG, EOG, and EEG recording using that.
BioAmp EXG Pill uses only one TL074H from Texas Instruments, for the internal workings of our BioAmp take a look at the schematic diagram shown below,
History of the BioAmp EXG Pill
It was started as a project for recording EMG signals only (from v0.1 to v0.6) but after dozens of prototypes and countless experiments, BioAmp EXG Pill (from v0.7 to v1.0) was born. All the BioAmp EMG Pill designs were prototyped at home with a toner transfer method and the v0.7 perfect purple PCBs were generously provided by OSHPark.
The BioAmp EXG Pill v1.0 is 57% smaller in size in comparison to BioAmp EMG Pill v0.1 and has better signal acquisition capabilities than all the versions before that. The project is at the beta stage of its development. The v1.0b PCBs will be of Black masking with ENIG finish from PCBWay. We are testing both glossy black and matt black PCBs from them.
schematic.pdf
Upside Down Labs BioAmp EXG Pill schematic diagram.
Adobe Portable Document Format - 62.41 kB - 04/14/2021 at 21:41
Preview
pill.zip
Gerber files for Upside Down Labs BioAmp EXG Pill v0.7 Upload this directly to oshpark.com to get your own tiny purple EXG pills :)
Zip Archive - 70.20 kB - 04/14/2021 at 21:37
Download
  • 1 × Upside Down Labs BioAmp EXG Pill PCB Printed Circuit Board
  • 1 × TL074HIPWR Quad Low-Noise JFET-Input Operational Amplifiers
  • 1 × 47uf 0805 capacitor
  • 5 × 100nf 0603 capacitor
  • 1 × 2.2uf 0603 capacitor
View all 13 components
View all 11 project logs
  • 1
    Order and assemble your own tiny Purple EXG Pill
    Order PCB at OSH Park here and then assemble it according to the image below
View all instructions
LuisCo123 wrote 09/16/2024 at 12:43 point
Good afternoon, how are you? I looked for the github project and didn't find anything that helped me with my question, which is: what is the formula to calculate the band pass filter and gain values to reach a specific frequency, like 74.5 - 149.5 Hz of the emg
Sara Macedo wrote 04/18/2023 at 23:10 point
Que trabalho fantástico, meus parabéns, não sou dessa área porém já vou tentar replicar-lo, pois fiquei curiosa quanto ao EMG.
Deepak Khatri wrote 04/22/2023 at 14:56 point
Muito obrigado, você também pode conferir nossos outros sensores EMG em https://www.tindie.com/stores/upsidedownlabs/
Eduardo Antonio Fragoso Dias wrote 01/18/2022 at 13:45 point
Is there any alternative to the TL074HIPWR ? it seems like it is ut of stock everywhere
Deepak Khatri wrote 02/10/2022 at 18:37 point
Hey, you can try other low noise quad opamps in tssop package!
cabrera.101 wrote 10/24/2021 at 05:46 point
Built a BioAmp EXG Pill with through-hole components.  Worked beautifully for ECG.  Will experiment on other uses.  Presently making a Pseudo-Medical entertainment device.  I'll post a link when done.
Deepak Khatri wrote 11/06/2021 at 04:01 point
Thanks for sharing your awesome project with us :)
what is the supply voltage for your through-hole TL074CN?
Deepak Khatri wrote 11/06/2021 at 04:03 point
Awesome, Which BioAmp EXG PIll version circuit did you use for your design?
cabrera.101 wrote 11/06/2021 at 15:49 point
Built the Rev 1.0b.  Powered by 3.3v.  Oddly, 47uf ceramic caps in thru-hole form are not common, which is why my builds have stacked 10uf caps.  I'll try a 47uf tantalum at some point.  Next, multiple units sharing a single amp-ref and DRL unit.
Deepak Khatri wrote 11/09/2021 at 02:13 point
Nice, Which op-amp did you use to make the circuit work at 3.3v?
Jacob wrote 08/31/2021 at 14:47 point
whats a typical power draw?
Deepak Khatri wrote 10/22/2021 at 18:19 point
It's less than 4mA, last time I checked DMM showed ~3.3mA
kubabuda wrote 08/29/2021 at 22:34 point
Could Bioamp pill work with handhelded electrodes, to get something like Kardia or that MobilECG card from few years back: https://makezine.com/2016/03/05/hold-this-smart-business-card-see-your-heart-beat ?
Deepak Khatri wrote 10/22/2021 at 18:20 point
yes, it totally works.
https://www.youtube.com/watch?v=5rHjvKB7c1o
intermelt wrote 08/26/2021 at 19:17 point
Love the simplicity of this!
You may want to update the description, the ESP32 can only support 3.3V on the ADC input. Maybe in a future revision you can add an optional voltage divider to the output so it could work with all 3.3V microcontrollers.
Deepak Khatri wrote 08/29/2021 at 18:01 point
Hey, thank you for your feedback. You are correct ESP32 will not be able to take the 5V output signal of BioAmp EXG Pill directly, as you said we require a voltage divider to use the pill with ESP32. The next version will hopefully be I2C/SPI compatible.
fizak3739 wrote 04/14/2021 at 23:43 point
your efforts at strengthening our culture have not gone unnoticed, "Fantastic work"!
Deepak Khatri wrote 04/15/2021 at 17:02 point
Thank you very much for your generous support, means a lot to me 💕
Deepak Khatri wrote 04/14/2021 at 22:40 point
You can contact us for any queries/feedback at https://upsidedownlabs.tech/contact-us/
