Secondlife UPS 2.0!
08/09/2023 at 19:37 • 0 commentsYou might be interested to know that a second version of the UPS has been built and described - https://hackaday.io/project/192297-secondlife-ups-mark-ii
Enjoy! -
Design refinements #2
04/25/2021 at 15:51 • 0 commentsI did another round of design refinements. This time I replaced the LM2596 converter supplying the 5V outputs to another XL4015 which has more current capacity.
This way I can reliably power the raspberry Pi as well as a fan colling the entire rack. I have added some stickers on the front panel as well:All changes were as usually reflected in the project details.
Design refinements #1
04/18/2021 at 14:31 • 0 commentsToday I have performed a number of design refinements:
- I rewired the output board to provide 6 x 12V output and 2 x 5V output as the 12V is much more versatile
- I improved the way that the AC 230V power cable attachment to the device, I have an electrical tube fitting instead of the cable just dangling out
- I added a 7812 V regulator to power the AC PSU Fan, powering it from the DC rail directly was working but the high-pitched sound was annoying
All of these have been reflected in the project details.
SVG not rendering in project details
04/15/2021 at 08:56 • 0 commentsIt looks like I can't add SVG to the project details page.
I have added a PDF version of the schematics as well as uploaded the Kicad project.
Energy density
04/13/2021 at 13:39 • 0 commentsI did some back of the envelope calculations on the energy density of my setup compared to lead-acid AGM batteries often used in UPS applications.
My setupa 4S10P battery made from junk cells each having around 800 mAh gives me 14.8 V x 8.315 Ah nominal capacity of 123.062 Wh (calculated by https://www.repackr.com/ battery pack builder). As the battery size is 27 cm x 10 cm x 4 cm this gives a volume of 1080 cm^3 and a volumetric energy density of 0.11 Wh/cm^3.
Lead-acid
A random "flat" AGM battery (CSB HRL 634W F2) used in a 1U rack UPS I found laying around in the hackerspace has a nominal capacity of 6 V x 9Ah = 54 Wh with the size of 15.1 cm x 3.4 cm x 9.4 cm without leads. This means that the volume is 482.596 cm^3 and the volumetric energy density of also 0.11 Wh/cm^3.
Not bad considering my lithium cells are essentially on the level of junk not reusable for anything else.
