20k_CdS_LDR_TSL2591_characterisation.xlsx
These are the readings from a 20kOhm (nominal) Light Dependent Resistor taken simultaneously with a TSL2591 light sensor using various configuration settings and then used to map Lux levels to anticipated ADC readings, if the LDR were installed in a voltage divider. Used to simulate a year of ADC readings using solar radiation data as the input.
sheet -
196.37 kB -
04/25/2021 at 16:03
