FC3000 D-PAD lacks a central pivot, so some combos are more difficult to do in some games.
It also allows opposite directions to be pressed simultaneously, (widely known as SOCD problem).
Sorry, I didn't take any picture before doing the cut, but IIRC the hole was already marked, so I just had to follow the circle mark.
I've enhanced the only 2 pictures I took after the cut:
The other not so good picture, but you get the idea:
3
Modify the DPAD adding a center ball
You can use whatever you can as a pivot-center ball, the important things are:
It must:
Be Rigid.
Be Resistant
Have a polished surface (to avoid friction).
Be Small enough to avoid touching the rubber pad.
In this case I used a short section of a plastic tube to generate a narrower fit and afterwards I pressed a ball from a cable managing system (you can find these in many electronic devices, it's an special cable tie).
Alternatives:
Use glue/epoxy instead of a tube to hold the pivot in place.
Use a 5mm led, the top dome is almost perfect for this (cut the legs and shorten the plastic body as much as needed). I've successfully used it with other ebay cheap controllers, those D-PAD had an inner hole of about 5mm, so it was the perfect choice.
