OUTER BEARING - 6810RS
PLANET BEARINGS - ANY 8mm outer Dia 3mm inner dia bearing
SHAFT - USE 3mm Stainess steel shaft cut in required lengths.
Mounting bolts - M3 Allen bolts
To build a small low cost actuator that can be used in quads and in robotic joints.
