PCB800869_from_Rouf.zipfor PCB800869 boards, from http://www.airdisp.com/; files provided by Rouf - thank you so much!Zip Archive - 10.78 MB - 01/14/2025 at 04:52 |
PCB800860-PCB800862-PCB800863-spec-programmer-instructions.zipSpecs from the manufacturer and instructions on the programmer. All in poor Chinese full of spelling errors. The pictures are somewhat useful.Zip Archive - 4.22 MB - 07/12/2024 at 18:18 |
PCB800860-PCB800862-PCB800863.zipFirmware for PCB800860, PCB800862, and PCB800863, three RTD2556 based controller boards. See the project log for more detail.Zip Archive - 9.82 MB - 07/12/2024 at 18:11 |
RTDCustomerTool_V3.8_20221101.zipBurner software for RTD based controllers.Zip Archive - 25.10 MB - 07/12/2024 at 18:11 |
display_pinouts.odsThe spreadsheet containing the pinout tables, that I have screenshot for eDP and LVDS pinout pagesspreadsheet - 19.83 kB - 08/13/2022 at 00:12 |
vga_hdmi_edp.binFirmware dumped directly from the flash chip of a RTD2556 board with HDMI and VGA ports. This is the board b from the list at https://hackaday.io/project/179868/log/195807octet-stream - 512.00 kB - 05/11/2022 at 10:04 |
EDP.zipFirmware files for eDP controllers. I found these files as 20201007043247EDP.rar - this is the same archive, but repackaged into a ZIP. Filename list is available at https://paste.debian.net/1240525/ , if you just want to see what kind of firmware files are inside.Zip Archive - 5.97 MB - 05/11/2022 at 10:01 |
hx6810.binMT6820 board firmware dump from the W25Q40.V 512KB SPI flash chip that's connected to the HX6810-A ICoctet-stream - 512.00 kB - 05/22/2021 at 10:29 |
