main_board.pdf
The PnPAssist Controller Board
Adobe Portable Document Format -
29.45 kB -
10/18/2021 at 07:41
Preview
PnPAssist_requirements_specs.pdf
55.21 kB -
10/14/2021 at 12:28
Preview
rulman_tut_orta.stl
Standard Tesselated Geometry -
80.36 kB -
08/30/2021 at 12:00
Download
BOM_Electronics_PnPAssist_V1.pdf
BOM file for PCB
29.13 kB -
08/12/2021 at 10:28
Preview
PnPAssist Screws and nuts.pdf
Screws and nuts used.
20.72 kB -
08/06/2021 at 08:18
Preview
PinMAP.pdf
PinMap of the controller board
18.73 kB -
07/31/2021 at 08:46
Preview
pnp_assist_tutac v1.stl
knobs
123.03 kB -
07/29/2021 at 16:39
Download
top_sheet_metal.dxf
AutoCAD DXF -
23.06 kB -
07/26/2021 at 19:38
Download
bottom_sheet_metal.dxf
AutoCAD DXF -
21.81 kB -
07/26/2021 at 19:38
Download
tutcak.stl
645.88 kB -
07/22/2021 at 08:40
Download
ust_rulmanlik3.stl
80.36 kB -
07/22/2021 at 08:40
Download
ust_arabalik.stl
119.81 kB -
07/22/2021 at 08:40
Download
rulmanlik.stl
83.87 kB -
07/22/2021 at 08:40
Download
buyuk_rulman_tut.stl
204.87 kB -
07/22/2021 at 08:40
Download
rulman_tut.stl
83.29 kB -
07/22/2021 at 08:40
Download
buyuk_rulman_kapak.stl
158.58 kB -
07/22/2021 at 08:40
Download
motor_tut.stl
119.42 kB -
07/22/2021 at 08:40
Download
rotator3.stl
25.38 kB -
07/22/2021 at 08:40
Download
ayak_ust_base_B.stl
103.60 kB -
07/22/2021 at 08:40
Download
ayak_ust_base.stl
78.70 kB -
07/22/2021 at 08:40
Download
bilezik.stl
39.54 kB -
07/22/2021 at 08:40
Download
lead t8 2mm pitch-duz_hex v2.stl
Main Gear Main Printing Settings: %100 infill 0.15 layer height Suggested Material : ASA
240.41 kB -
07/22/2021 at 08:38
Download
