The box and supporting structure is made from hardware store Poplar. A rectangular box surrounds the display boards. The boards are held off the grid using 10mm M3 standoff because that is what you can get quickly from Amazon. The standoffs are held to the PWB using hot snot (aka hot glue). Not the best approach but works.
