Uses an E-ink Display to Realtime Update Select Crypto Currencys
Cryptoink Base.stlStandard Tesselated Geometry - 9.56 MB - 06/11/2021 at 16:21 |
Cryptoink Top.stlStandard Tesselated Geometry - 15.62 MB - 06/11/2021 at 16:21 |
crypto-ink - ThingSpeak.txtplain - 2.50 kB - 06/03/2021 at 18:25 |
Image2Lcd.zipx-zip-compressed - 511.31 kB - 06/03/2021 at 03:54 |
CRYPTOiNK_-_REV5_Fully_Working.zipapplication/zip - 17.50 kB - 06/03/2021 at 02:44 |
I assemble and painted the Housing to be more appealing and to hid the 3d print layer lines
I designed this housing to Secure the CRYPTOiNK Hardware to any Refrigerator. I uses 2 long magnets to secure it to most steel doors and has suction cups if the door is non-magnetic.
CRYPTOiNK uses a TP4056 Charger to charge a 6000mAh Lipo Battery. Built into the Charger is a Low Voltage, Over Voltage, and Over Current Protection Circuit.
Because the Ilpo battery does not provide a constant voltage and ranges from 3.4 - 4.2V, a MT3608 DC/DC Boost Module to provide a consistent Voltage for the Waveshare Driver board to regulate down to a 3.3V that is used by the ESP8266 and Eink Display.
Goals:
1) A Low Powered E-Paper Display
2) Graphically Display Cryptocurrency Data
3) Attach to a Refrigerator or Door (Magnets and Suction Cups)
4) Update on a 10min Basis
5) Visible 6-12Ft
//----------------------Extended Goals----------------------
5) Encoder wheel + OLED to input SSID and Passoword
6) Buttons that, when pressed, go into details of each Cryptocurrency
//-----------------Estimated BOM-------------------
The Standard hardware for this Project are:
1) 1x Waveshare Esp8266 E paper Driver
2) 1x Waveshare 7.5" B/W/R E paper (640x384)
3) 7x 12mm Tactile Buttons
4) 1x Encoder (For Wifi Setup)
5) 1x OLED Display (For Wifi Setup)
I Started out using the GxEPD2 Library to create the format
I Used Kevin Darrah's E-paper Tutorial on how to crate graphics for the E-Paper Display using the tool Image 2 LCD (https://cdn.hackaday.io/files/1799517699023584/Image2Lcd.zip)
Using this Tutorial I was able to produce a format that can be seen from 6-12ft Away
The first Step is to make a List of the Crypto that you would like to be Displayed.
Sign up and Register your ThingSpeak Account
Once Registered open the ThingHTTP under the APPs
Then Create a new ThingHTTP
Now the 4 Things we need to input are the NAME, URL, HTTP Version, and Parse String
URL: https://coinmarketcap.com/currencies/tron/
HTTP: 1.0
Parse String :
Now Choose a Reliable Crypto Exchange you would like to pull Data From I Suggest CoinMarketCAP
CRYPTOiNK is a new way to experience cryptocurrency! Unlike smartphones, the CRYPTOiNK's e-ink display enables currency prices to be updated in real-time while watching traditional news or displaying security information. Tipping, polls, and social media have never been easier! Displayed on the face of the CRYPTOiNK are the currencies being traded and their current value. However, before that, it is necessary to learn about digital marketing. You can explore https://www.ultraupdates.com/2020/05/how-to-study-digital-marketing-online-for-free/ article to find out from where you can get the degree of digital marketing online for free. It will help you.
SAYANTAN PAL
Tahmid
Tom Nardi
Hello, I love this project, i would like to build one, but is there anyone can show a photo inside the box (where to fix item) ? Thank you !
