Final Video
11/04/2021 at 18:01 • 0 commentsHere is the final video for my project :) It's just a simple overview
Final Build Boots
11/03/2021 at 22:11 • 0 comments -
Final Build Complete!
10/26/2021 at 00:45 • 0 comments![]()
The build is complete! Here is the latest and final blog post!
Printed Mechanical Enclosure
10/18/2021 at 17:07 • 0 commentsI've dusted off the old 3D printer and printed the mechanical enclosure, so amazing seeing it come to life! I'm hoping to get a full build finished this week! Stay tuned. PS Blog post 3 is up.
Form Factor Boards Arrive!
09/23/2021 at 16:32 • 0 commentsThe boards have arrived! And with that another blog post is live! Link to newest blog post here.
Mains Blade Interface
07/27/2021 at 17:43 • 0 commentsI've been scouring the internet trying to find an off-the-shelf part like this...
The part circled above it is a through-hole stamped part that makes contact with the blade connector, it's the power entry connector for the board. It's an extremely low-cost connector that has to be done right. If the component is to fail it could short against other components causing a fire. The component that actually plugs into the wall is custom as well and is "insert moulded" directly into the case itself. As I couldn't find any existing component I would have to draw one up myself, being new to FreeCAD and mechanical engineering I knew this one would be a challenge. Poking around enough, I found the Sheet Metal Toolbox to be the tool. This toolbox is for sheet metal, you lay out a flat design and add bends where you please. As a starting point, I desoldered a contact from the board above and flattened it out...
Then sketched it flat...
To make bends you sketch a line, then click the line and face. You define a bend angle and bend radius.
I then integrated it into the board file in Kicad exported a step file and reimported it into the FreeCAD assembly, there is still some alignment to be done but it's good enough for now.
Until next time ;) !
[ 1.042110] Waiting for root device /dev/mmcblk0p1...
07/01/2021 at 17:30 • 0 commentsBuildroot is a cruel mistress... I've started building the image from the A33-OLinuXino. I used the open source files from this as a reference design for the wifi wart; I thought it would be a breeze. It turns out the PMIC used by Olinux has all the bells and whistles, I2C for control which u-boot (system bootloader) needs to configure voltages and whatnot. After ripping all that code out, I got to a point where the bootloader jamming the kernel into RAM and changing the program counter to the start address. However, I'm getting stuck on some mmc stuff...
U-Boot SPL 2021.01 (Jun 30 2021 - 12:27:42 -0700) DRAM: 1024 MiB Trying to boot from MMC1 U-Boot 2021.01 (Jun 30 2021 - 12:27:42 -0700) Allwinner Technology CPU: Allwinner A33 (SUN8I 1667) Model: Olimex A33-OLinuXino DRAM: 1 GiB MMC: mmc@1c0f000: 0 Loading Environment from FAT... Unable to use mmc 0:1... Setting up a 800x480 lcd console (overscan 0x0) In: serial Out: vga Err: vga Net: No ethernet found. starting USB... Bus usb@1c19000: No host cable detected: Port not available. Hit any key to stop autoboot: 2 1 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 294 bytes read in 2 ms (143.6 KiB/s) ## Executing script at 43100000 21702 bytes read in 3 ms (6.9 MiB/s) 4058272 bytes read in 187 ms (20.7 MiB/s) ## Flattened Device Tree blob at 49000000 Booting using the fdt blob at 0x49000000 Using Device Tree in place at 49000000, end 490084c5 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 5.0.0 (machinehum@whitebox) (gcc version 10.3.0 (Buildroot 2021.05-280-g6dd9e246a7)) #1 SMP Wed Jun 30 11:51:11 PDT 2021 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: Olimex A33-OLinuXino [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] cma: Reserved 16 MiB at 0x7dc00000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: Using PSCI v0.1 Function IDs from DT [ 0.000000] random: get_random_bytes called from start_kernel+0x98/0x3fc with crng_init=0 [ 0.000000] percpu: Embedded 16 pages/cpu @(ptrval) s34572 r8192 d22772 u65536 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260233 [ 0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p1 rootwait panic=10 [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 1011440K/1047076K available (6144K kernel code, 436K rwdata, 1516K rodata, 1024K init, 242K bss, 19252K reserved, 16384K cma-reserved, 244248K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (7136 kB) [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB) [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 437 kB) [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 243 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000019] Switching to timer-based delay loop, resolution 41ns [ 0.000180] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000520] Console: colour dummy device 80x30 [ 0.000575] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.000588] pid_max: default: 32768 minimum: 301 [ 0.000719] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000735] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001397] CPU: Testing write buffer coherency: ok [ 0.001795] /cpus/cpu@0 missing clock-frequency property [ 0.001814] /cpus/cpu@1 missing clock-frequency property [ 0.001828] /cpus/cpu@2 missing clock-frequency property [ 0.001843] /cpus/cpu@3 missing clock-frequency property [ 0.001855] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.002380] Setting up static identity map for 0x40100000 - 0x40100060 [ 0.002513] rcu: Hierarchical SRCU implementation. [ 0.003183] smp: Bringing up secondary CPUs ... [ 0.003981] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.004863] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.005683] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.005764] smp: Brought up 1 node, 4 CPUs [ 0.005785] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.005791] CPU: All CPU(s) started in HYP mode. [ 0.005795] CPU: Virtualization extensions available. [ 0.006787] devtmpfs: initialized [ 0.011886] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 0.012099] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.012123] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.012974] pinctrl core: initialized pinctrl subsystem [ 0.013933] NET: Registered protocol family 16 [ 0.015096] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.016082] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.016092] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.027517] SCSI subsystem initialized [ 0.028001] usbcore: registered new interface driver usbfs [ 0.028047] usbcore: registered new interface driver hub [ 0.028118] usbcore: registered new device driver usb [ 0.028309] pps_core: LinuxPPS API ver. 1 registered [ 0.028315] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [ 0.028333] PTP clock support registered [ 0.028554] Advanced Linux Sound Architecture Driver Initialized. [ 0.029314] clocksource: Switched to clocksource arch_sys_counter [ 0.037047] NET: Registered protocol family 2 [ 0.037557] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes) [ 0.037586] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.037657] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.037772] TCP: Hash tables configured (established 8192 bind 8192) [ 0.037906] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.037983] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.038212] NET: Registered protocol family 1 [ 0.038745] RPC: Registered named UNIX socket transport module. [ 0.038758] RPC: Registered udp transport module. [ 0.038764] RPC: Registered tcp transport module. [ 0.038768] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.040470] workingset: timestamp_bits=30 max_order=18 bucket_order=0 [ 0.047071] NFS: Registering the id_resolver key type [ 0.047117] Key type id_resolver registered [ 0.047123] Key type id_legacy registered [ 0.049551] bounce: pool size: 64 pages [ 0.049628] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248) [ 0.049640] io scheduler mq-deadline registered [ 0.049647] io scheduler kyber registered [ 0.050495] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO [ 0.051248] sun8i-a23-r-pinctrl 1f02c00.pinctrl: Reset controller missing [ 0.053940] sun8i-a33-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [ 0.099289] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 0.101107] sun8i-a33-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator [ 0.101215] sun8i-a33-pinctrl 1c20800.pinctrl: Linked as a consumer to regulator.0 [ 0.102002] printk: console [ttyS0] disabled [ 0.122187] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 32, base_baud = 1500000) is a U6_16550A [ 0.779019] printk: console [ttyS0] enabled [ 0.787909] libphy: Fixed MDIO Bus: probed [ 0.792063] CAN device driver interface [ 0.796497] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.803037] ehci-platform: EHCI generic platform driver [ 0.808506] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.814707] ohci-platform: OHCI generic platform driver [ 0.821139] sun6i-rtc 1f00000.rtc: registered as rtc0 [ 0.826190] sun6i-rtc 1f00000.rtc: RTC enabled [ 0.830891] i2c /dev entries driver [ 0.835347] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 0.845317] sun8i-a33-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator [ 0.856186] sun4i-ss 1c15000.crypto-engine: Die ID 5 [ 0.863746] usbcore: registered new interface driver usbhid [ 0.869357] usbhid: USB HID core driver [ 0.874556] NET: Registered protocol family 17 [ 0.879020] can: controller area network core (rev 20170425 abi 9) [ 0.885329] NET: Registered protocol family 29 [ 0.889788] can: raw protocol (rev 20170425) [ 0.894054] can: broadcast manager protocol (rev 20170425 t) [ 0.899731] can: netlink gateway (rev 20170425) max_hops=1 [ 0.905455] Key type dns_resolver registered [ 0.909816] Registering SWP/SWPB emulation handler [ 0.924325] sun8i-a23-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver [ 0.933016] sun8i-a33-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator [ 0.943725] sun8i-a23-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator [ 0.953904] sun8i-a23-r-pinctrl 1f02c00.pinctrl: Linked as a consumer to regulator.0 [ 0.961739] sunxi-rsb 1f03400.rsb: RSB running at 3000000 Hz [ 0.967698] sunxi-rsb 1f03400.rsb: /soc/rsb@1f03400/pmic@3a3: set runtime address failed: -22 [ 0.976473] axp20x-rsb sunxi-rsb-3a3: AXP20x variant AXP223 found [ 0.983338] axp20x-rsb sunxi-rsb-3a3: Failed to set masks in 0x40: -5 [ 0.989793] axp20x-rsb sunxi-rsb-3a3: failed to add irq chip: -5 [ 0.995876] axp20x-rsb: probe of sunxi-rsb-3a3 failed with error -5 [ 1.003994] sun8i-a33-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator [ 1.016153] sun8i-a33-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator [ 1.026719] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4) [ 1.034966] ALSA device list: [ 1.037933] No soundcards found. [ 1.042110] Waiting for root device /dev/mmcblk0p1...
Machinehum (Ryan Walker)
