[TESTING] - URUS Graphic Acceleration on Raspberry Pi2
09/26/2019 at 03:12 • 0 commentsURUS Graphic Acceleration by hardware (Rasperry's GPU Broadcom VideoCore4 VC4) developed and integrated on URUS's SO via Erick Anholt's GalliumVC4 DKMS driver!
[NEWS] - Barometric pressure and altitude bench test application
06/24/2019 at 07:45 • 0 commentsAdvanced High Precision Realtime Barometric Pressure and Altimeter Bench Test Application, FAA TSO 88a and ICAO CODE Altitude compliant.
Development by Hiroshi Takey F.
at Fenix Laboratory & Research division for Avionics Technology, in cooperation and technical support with FAA Licensed Maintenance Engineering Aircfraft, Rudy Averanga.The system was developed with UrusStudio and URUS Project.
[NEWS] - Testing URUS OS Graphical Interface on Raspberry Pi 2
06/17/2019 at 21:13 • 0 commentsTesting the new URUS OS graphical interface and running an application developed with UrusStudio. Only 12 seconds booting up to the graphical application test!!!
[NEWS] - Testing URUS OS System on Samsung Galaxy Grand Prime
05/27/2018 at 22:04 • 0 comments -
Testing throtle for Beechcraft Air King simulator 1:1 cockpit scale.
03/21/2018 at 06:13 • 0 commentsTesting throtle for Beechcraft Air King simulator 1:1 cockpit scale.
The system was developed for use with URUS SHAL on APM 2.x board (for now) and up APM board versions. But as you can see it could run on an Arduino mega board too.
The source code is available at: https://github.com/UrusTeam/URUS
Thanks for everyone that make it possible to the world.
[URUS TEST] - Testing URUS Joypad usb example (infrared sensor)
01/04/2018 at 03:23 • 0 commentsThis is a demo running URUS VR Joypad driver example with infrared sensor on Arduino mega connected via USB to Linux/Debian pc, this should work on any other OSes.
Infrared sensor is attached to X axis Analog GPIO input, the "smooth" process is performed by APM filter Library on URUS SHAL.
Testing Virtual Reality Joystick example based on IMU 10-DOF APM 2.x Boards.
12/30/2017 at 19:25 • 0 commentsTesting Virtual Reality Joystick example based on IMU 10-DOF high speed sytem with APM 2.x board. NO HOST DRIVERS needed, this work directly on any platform!
This example will be available on the URUS github repo, right now we have pushed 70% code. We hope to push it on the next week.
We have opened a gitter channel for developers https://gitter.im/UrusTeam/URUS and a FB Group for updates and news at https://www.facebook.com/groups/1804355869803790/
For sure, it's free, it's URUS!!! #URUSDev #URUSTechnology #APMDev #Ardupilot
[GPS] - Parsing NMEA protocol MTK GPS.
11/22/2017 at 04:05 • 0 commentsParsing NMEA protocol from Mediatek GPS at 10Hz with AP_GPS master-AVR library fusioned onto master APM (Posix/Unix) branch running through URUS SHAL.
The hardware is a Multiwii RED board, this come with atmega2560 cpu micro.
TETRIS game with RC Controller on Arduino Nano!
11/15/2017 at 03:17 • 0 commentsTetris game with RC Controller on Arduino Nano!
Testing URUS SHAL and APM Scheduler doing multitasking process between RC input capture, game process and ASCII rendering game via UART at real time!
[TEST] - Testing URUS RCOutput driver on proteus.
10/23/2017 at 23:56 • 0 commentsTesting URUS Synthetic Hardware Abstraction Layer (SHAL) RCOutput driver example on Proteus.
