Speeding Up the IOP16 CPU
07/03/2021 at 20:47 • 0 commentsThe IOP16 runs at 8 of 50 MHz clocks per instruction. That is 6.25 MIPS which really is way more than fast enough for this use. The states are Grey Coded as follows:
Most of the cycles do nothing. There is no good reason this can't run twice as fast. The Grey Codes are:
Made the change and it worked. It now runs at 12.5 MIPS. Way overkill, but why not.
Fixed PS/2 Backspace Key
07/03/2021 at 14:09 • 0 commentsThe backspace key that the PDP-8 expects isn't the CTRL-H key (0x08 ASCII value) . The key needs to be mapped to ASCII 0x7F. Fortunately, the PS/2 keyboard VHDL code (ps2_keyboard_to_ascii.vhd) makes this easy to change.
It works!
Auto-detect Serial Source
07/03/2021 at 13:33 • 0 commentsIt's a great retro feeling to use the amber VDU screen and PS/2 keyboard built into the FPGA. However, sometimes I prefer to use PuTTY on the USB serial terminal, particularly when I want to capture screens. But the use of the serial source jumper does present the possibility of confusion to which port is being used (VDU or USB serial).
Added auto-detection of the Serial port source. If the serSelect jumper (J3-1) is installed the USB is used. The serSelect is routed to the IOP16 CPU and checked. If USB is selected, the VDU screen shows "USB" added to the banner. This is useful to let the user know that the VDU is not being used.
Output on PuTTY:
Improved ANSI Screen
07/02/2021 at 09:49 • 0 commentsAdded subroutines for UART and VDU initialization to the IOP16 code. Also, added an ANSI screen clear command (0x0c). Here's a handy ANSI codes chart.
Here's the IOP16 code (latest version is here).
000 START 0xA017 JSR INITVDU INITIALIZE THE VDU 001 0xA01C JSR INITURT INITIALIZE THE ACIA UART 002 0xA014 JSR CLRSCR CLEAR THE SCREEN CMD 003 LOOP 0xA006 JSR KB2PDP KEYBOARD TO PDP-8 004 0xA00D JSR PDP2VDU PDP-8 TO VGA 005 0xE003 JMP LOOP LOOP FOREVER 006 KB2PDP 0x6004 IOR Reg0 IO_04 READ KBD STATUS 007 0x8001 ARI Reg0 0X01 MASK RX DATA PRESENT BIT 008 0xC004 BEZ NOKDBD NO KBD DATA 009 0x6105 IOR Reg1 IO_05 READ KBD DATA 00a 0x9180 ORI Reg1 0X80 MARK PARITY 00b 0x7101 IOW Reg1 IO_01 WRITE TO UART DATA 00c NOKDBD 0xB000 RTS DONE KEYBOARD TO UART 00d PDP2VDU 0x6000 IOR Reg0 IO_00 PDP-11 TO VDU 00e 0x8001 ARI Reg0 0X01 MASK RX DATA PRESENT BIT 00f 0xC004 BEZ NOPDPD NO UART DATA 010 0x6101 IOR Reg1 IO_01 READ UART DATA 011 0x817F ARI Reg1 0X7F 8 TO 7 BITS 012 0x7103 IOW Reg1 IO_03 WRITE OUT SCREEN 013 NOPDPD 0xB000 RTS DONE UART TO VGA 014 CLRSCR 0x200C LRI Reg0 0X0C SCREEN CLEAR 015 0x7003 IOW Reg0 IO_03 WRITE OUT SCREEN 016 0xB000 RTS 017 INITVDU 0x2003 LRI Reg0 0X03 RESET TERMINAL COMMAND 018 0x7002 IOW Reg0 IO_02 WRITE VDU CMD REG 019 0x2020 LRI Reg0 0X20 TX CTRLS RTS 01a 0x7002 IOW Reg0 IO_02 WRITE VDU CMD REG 01b 0xB000 RTS 01c INITURT 0x2003 LRI Reg0 0X03 RESET UART COMMAND 01d 0x7000 IOW Reg0 IO_00 WRITE UART CMD REG 01e 0x2020 LRI Reg0 0X20 TX CTRLS RTS 01f 0x7000 IOW Reg0 IO_00 WRITE UART CMD REG 020 0xB000 RTS
Built in ANSI Terminal
07/02/2021 at 00:16 • 1 commentThere was enough resources to put my ANSI Terminal into the FPGA. It displays on a VGA monitor and input comes from a PS/2 keyboard. The ANSI Terminal uses my IOP16 CPU. The terminal connects via an internal 9600 baud serial connection.
The IOP16 code is pretty simple. The only "tricky" part is adding MARK parity when sending serial data to the PDP-8 serial in and stripping off the MARK parity when sending the data out of the PDP-8 into the VDU.
000 0x2003 LRI Reg0 0X03 RESET TERMINAL COMMAND 001 0x7002 IOW Reg0 IO_02 WRITE VDU CMD REG 002 0x2003 LRI Reg0 0X03 RESET UART COMMAND 003 0x7000 IOW Reg0 IO_00 WRITE UART CMD REG 004 0x2020 LRI Reg0 0X20 TX CTRLS RTS 005 0x7002 IOW Reg0 IO_02 WRITE VDU CMD REG 006 0x2020 LRI Reg0 0X20 TX CTRLS RTS 007 0x7000 IOW Reg0 IO_00 WRITE UART CMD REG 008 START 0xA00B JSR KB2PDP KEYBOARD TO PDP-8 009 0xA012 JSR PDP2VDU PDP-8 TO VGA 00a 0xE008 JMP START LOOP FOREVER 00b KB2PDP 0x6004 IOR Reg0 IO_04 READ KBD STATUS 00c 0x8001 ARI Reg0 0X01 MASK RX DATA PRESENT BIT 00d 0xC004 BEZ NOKDBD NO KBD DATA 00e 0x6005 IOR Reg0 IO_05 READ KBD DATA 00f 0x9080 ORI Reg0 0X80 MARK PARITY 010 0x7001 IOW Reg0 IO_01 WRITE TO UART DATA 011 NOKDBD 0xB000 RTS DONE KEYBOARD TO UART 012 PDP2VDU 0x6000 IOR Reg0 IO_00 PDP-11 TO VDU 013 0x8001 ARI Reg0 0X01 MASK RX DATA PRESENT BIT 014 0xC004 BEZ NOPDPD NO UART DATA 015 0x6001 IOR Reg0 IO_01 READ UART DATA 016 0x807F ARI Reg0 0X7F 8 TO 7 BITS 017 0x7003 IOW Reg0 IO_03 WRITE OUT SCREEN 018 NOPDPD 0xB000 RTS DONE UART TO VGA
Resources
It worked!
FPGA Resources
05/30/2021 at 19:36 • 0 commentsUses most of the internal SRAM. Plenty of logic space left over:
Enabled Hardware Handshake on TTY1
05/30/2021 at 19:32 • 0 commentsThought it might be a useful idea to have hardware handshake enabled.
In the top file CPU entity:
-- TTY1 Interfaces tty1BR => uartBR9600, --! TTY1 is 9600 Baud tty1HS => uartHShw, --! TTY1 uses hardware handshake tty1CTS => TTY1_CTS, --! TTY1 CTS (in) tty1RTS => TTY1_RTS, --! TTY1 RTS (out) tty1RXD => TTY1_RXD, --! TTY1 RXD (to RS-232 interface) tty1TXD => TTY1_TXD, --! TTY1 TXD (to RS-232 interface)From Doug Jones PDP-8 page. "From the beginning, PDP-8 software has generally assumed that textual I/O would be in 7 bit ASCII. Most early PDP-8 systems used teletypes as console terminals; as sold by DEC, these were configured for mark parity, so most older software assumes 7 bit ASCII, upper case only, with the 8th bit set to 1. "
In PuTTY:
Works!
Running OS/8
05/30/2021 at 18:13 • 0 commentsFresh Boot
- USB cable disconnected (FPGA card is off).
- Run/Halt on Front Panel set to HALT (down position).
- Set Address switches on Front Panel to 0023.
- Plug in USB cable to PC.
- PC LED on Front Panel should display next address (0024).
- Run PuTTY on PC.
- Serial port found in device Manager.
- Serial port set to 9600,SPACE,7,1 (may not be optimal but it worked).
- Turn on RUN switch on Front Panel.
- Press RES button on Front Panel.
- Prompt comes up in Serial terminal (PuTTY).
Reboot
The Internal SRAM needs to reloaded.
- Run/Halt on Front Panel to HALT (down position).
- Hit load switch on FPGA card (SW3).
Alternate Re-boot
From the OS8 Handbook. Boots to command line.
- Set Run/Halt to HALT
- Set switches to 7600
- Press RES (Reset)
- Press LDPC (Load PC)
- Press RES (Reset)
- Set Run/Halt to RUN
- Press RES
Files on the RK08 (SD Card)
- DIR /A
ABSLDR.SV 6 FLOP2 .BI 2 RALF .SV 19 ADVENT.DC 9 FORLIB.RL 170 REMEM .SV 5 ADVENT.FT 11 FOTP .SV 8 RESORC.SV 14 ADVENT.IN 1 FRTS .SV 26 RKBOOT.SV 2 ADVENT.LD 145 FUGUE .MU 42 RKCOPY.SV 11 ADVENT.RL 4 FUTIL .SV 27 RKFRMT.SV 9 ADVENT.TX 201 F4 .SV 20 RKUTIL.SV 15 AINDX .DA 50 GETIN .FT 6 RLFRMT.SV 7 AMAIN .RA 270 GETIN .RL 4 RL2FMT.SV 8 AMAIN .RL 50 GETWRD.RA 16 RND .FT 1 ATEXT .DA 144 GETWRD.RL 2 RND .RL 2 A5TOA1.RA 6 HEADER.SV 14 RSPEAK.RA 3 A5TOA1.RL 3 HELP .HL 102 RSPEAK.RL 2 BASIC .AF 4 HELP .SV 8 RSTRGM.FT 13 BASIC .BA 11 INIT .TX 1 RSTRGM.RL 8 BASIC .FF 4 INITAD.FT 65 RTFLOP.SV 15 BASIC .OV 16 INITAD.RL 23 RUNAD .BI 1 BASIC .SF 4 INUSE .TE 8 RXCOPY.SV 9 BASIC .SV 11 IO .FT 2 RXFIX .SV 3 BASIC .UF 2 IO .RL 2 RXREAD.SV 7 BASIC .WS 1 JUGGLE.RA 3 SAVEGM.FT 13 BATCH .SV 10 JUGGLE.RL 2 SAVEGM.RL 8 BCOMP .SV 17 KL8E .PA 53 SD .BN 1 BITMAP.SV 5 K12DEB.SV 4 SD .LS 28 BITSET.RA 11 K12DEC.SV 5 SD .PA 11 BITSET.RL 3 K12DJG.SV 33 SEED .RA 7 BLOAD .SV 8 K12ENB.SV 4 SEED .RL 2 BLOCKS.SV 8 K12ENC.SV 6 SET .SV 20 BOOK .BI 1 K12MIT.SV 33 SPACWR.BA 39 BOOT .SV 5 LAYOUT.TX 4 SPEAK .RA 28 BRTS .SV 15 LCSYS .BI 3 SPEAK .RL 4 BUG .FT 3 LOAD .BI 1 SRCCOM.SV 5 BUG .RL 2 LOAD .LS 8 SVDUMP.SV 4 BUILD .SV 37 LOAD .SV 16 TDCOPY.SV 7 CAMP .SV 13 LPTSPL.SV 10 TDFRMT.SV 9 CARRY .RA 5 MCPIP .SV 13 TECKBM.TE 2 CARRY .RL 2 MOVE .RA 4 TECO .IN 1 CCL .SV 31 MOVE .RL 2 TECO .SV 32 CHESS .SV 15 MSBAT .SV 23 TECO .TE 1 COMPAF.SV 5 MUSIC .SV 9 UCSYS .BI 3 COMPIL.BI 2 PAL8 .SV 19 USR .RA 46 CONVRT.SV 5 PARAM .SV 12 USR .RL 4 CREF .SV 13 PASS2 .SV 20 VOCAB .RA 7 DECX8 .SV 43 PASS2O.SV 5 VOCAB .RL 3 DIRECT.SV 7 PASS3 .SV 8 VTEDIT.TE 8 DOUGTE.ST 1 PCT .RA 2 WILD .BI 1 DROP .RA 4 PCT .RL 2 WILD .DI 5 DROP .RL 2 PIP .SV 11 WILD .TE 2 DSTROY.RA 1 PIP10 .SV 17 WILD .TM 1 DSTROY.RL 2 PSPEAK.RA 5 WPFLOP.SV 14 DTCOPY.SV 5 PSPEAK.RL 2 YES .FT 2 DTFRMT.SV 7 PUT .RA 3 YES .RL 3 EDIT .SV 10 PUT .RL 2 2000 .TX 1 EPIC .SV 14 QUIT .SV 2 31 .76 1 FLOP .HN 3
Resources
.R RESORC */E 163 FILES IN 2639 BLOCKS USING 5 SEGMENTS 553 FREE BLOCKS (7 EMPTIES) # NAME TYPE MODE SIZ BLK KIND U V ENT USER 01 SYS RK8E RWF 3248 SYS 0 F 07 02 DSK RK8E RWF 3248 SYS 0 F 07 03 BAT BAT R 16 B 00 04 TTY TTY RW 17+ KL8E E 176 05 RKA0 RK8E RWF 3248 20 RK05 0 A 20 06 RKB0 RK8E RWF 3248 20 RK05 0 A 21 07 RKA1 RK8E RWF 3248 20 RK05 1 A 22 10 RKB1 RK8E RWF 3248 20 RK05 1 A 23 11 RKA2 RK8E RWF 3248 20 RK05 2 A 24 12 RKB2 RK8E RWF 3248 20 RK05 2 A 25 13 RXA0 RX02 RWF 988 21+ 32 14 RXA1 RX02 RWF 988 21+ 36 15 B3 37 RWF 22+ 117 16 B4 37 RWF 22+ 113 FREE DEVICE SLOTS: 01, FREE BLOCK SLOTS: 03 OS/8 V3T
Creating SD Card
05/30/2021 at 18:04 • 0 commentsRunning VirtualBox under Windoze. Transferring files between Windoze and Linux via GitHub.
Combined the 4 images inspired by Startup page:
- http://www.pdp8online.com/ftp/images/os8/multos8.rk05
- http://www.pdp8online.com/ftp/images/os8/diag-games-kermit.rk05
- http://www.pdp8online.com/ftp/images/os8/diagpack2.rk05
- http://www.rickmurphy.net/advent/advent.rk05
Created single image.
Burned to blank SD card using Balena Etcher.
Boot OS/8 from SD Card
05/30/2021 at 17:13 • 0 commentsOS/8 Boots:
Set serial port configuration:
land-boards.com
