1Step 1
# Connections
For Display ( 2.8" TFT Display ILI9341)
1. Raspberry Pi 3.3V power to TFT Vin.
2. Raspberry Pi ground to TFT GND.
3. Raspberry Pi SCLK to TFT CLK.
4. Raspberry Pi MOSI to TFT MOSI.
5. Raspberry Pi CE0 to TFT CS.
6. Raspberry Pi GPIO 18 to TFT D/C.
7. Raspberry Pi GPIO 23 to TFT RST.And for Bluetooth Connection:
* Connect the device : `bluetoothctl connect 9F:3A:66:06:7C:EA` the id is id of your headset , you can find it when scanning on your phone.For Speaker:
* Connect the Aux Cable Directly to Raspberry Pi# To Run the Bot:
1. Install the Adafruit Display Library on RPi:
cd ~
git clone https://github.com/adafruit/Adafruit_Python_ILI9341.git
cd Adafruit_Python_ILI9341
sudo python setup.py install
2. Install the Python Packages:
pip3 install pyttsx Adafruit_GPIO Pillow nltk sklearn speech_recognition
3. Make the Connections and Connect the Bluetooth Headset
4. Then Run the Bot
git clone https://github.com/aniketdhole07/emojo_chatbot
cd emojo_chatbot
python3 main.py
aniketdhole
