Hackaday prize video entry was uploaded!
11/13/2021 at 23:35 • 0 comments -
Twitter Account
08/27/2021 at 17:21 • 0 commentsDo you know I have a twitter account?
I'm trying to push this project up sharing a lot of content about it on twitter, some time lapse videos, fotos and new PCB & 3D designs.Please consider follow me and subscribe to this project!
Thanks!
Arrived new PCB design
08/23/2021 at 19:38 • 0 commentsHI all,
today arrived the last design of the tiny PCB for handwired keyboards.As I anticipated days ago, new PCB bring us the possibility of solder the led in two ways, inverting the direction of the data pins. Now, wire the lED, will be easier (I hope) for all of you.
Once you solder the LED you have to mark the white square (to know whats the direction of this PCB)
Working in progress Kailh Low Profile switches
08/16/2021 at 22:14 • 0 commentsHi all!
I've looking around aliexpress and founded these switches:
https://es.aliexpress.com/item/4000803757746.html
These switches have a more compact size, with shorter total travel, I've write the footprint for these switches:
I'll upload the PCB version of my project for this footprint
Finished numpad keyboard
08/14/2021 at 10:52 • 0 commentsHi all, just finished wiring and programming of my numpad keyboard using the same PCB used at the dactyl manuform keyboard, hope you like it!
New PCB design!
08/04/2021 at 09:24 • 0 commentsHi all,
I've designed a new PCB to improve some features:
1.- Added 2 gaps for mechanical support for some switches2.- Connector pads are now through hole, are smaller too, but is necessary to add the to gaps described before.
3.- now you can mount the sk6812 4020 twisted 180º too, so it swap the direction pin:
Now there isn't DIN or DOUT silkscreen to indicate the data direction, when you solder the led you set de direction pin too.
Added numpad to equipment
07/18/2021 at 08:40 • 0 commentsI also build a numpad to show you how PCBs can fit in any form factor keyboard.
These PCBs can be used to build macro-keyboards with under glow keys too!
PCB description
06/02/2021 at 22:57 • 0 commentsPCB desing, it fits into more difficult places inside the dactyl manuform
PCB size information
Finished keyboard
06/02/2021 at 22:54 • 0 commentsA pick of the finished keyboard, and some lights animations
