Hi, so this project is divided into two versions.
Version 1 is the breadboard version and Version 2 is the Proper Gameboy with custom PCB and 3D Printed Body.
In the Build Instructions, I have included the built guide for both versions so you can make the breadboard version of this project or build the PCB Edition.
V1-
V2-
Basic Setup
I'm using a 4.3-inch display in this setup which is pretty huge if compared with a regular Gameboy screen so this setup size will be around 135mm x 140mm.
On the front side, there's a display and buttons and on the bottom side, raspberry pi zero along with a boost converter circuit and a Li-Ion Cell will be placed. This Setup is a combination of PCB and 3D Printed Body which will be connected together via screws through the given mounting holes in the PCB
Arnov Sharma
furrysalamander
