Display connector problem
A project log for VT100 simulator and 3D printed replica
Simulator for the VT100 hardware. Running inside Gardi's 3D model.
lars-brinkhoffLars Brinkhoff 06/13/2021 at 16:106 Comments
It doesn't seem to fit.  The board layout seems slight different from other pictures I have seen.  Maybe it's a mismatch?
Michael Gardi wrote 06/13/2021 at 17:14 point
Someone over on Instructables had the exact same problem:
Sadly, the Pimoroni box from Digi-Key had the wrong display driver board inside. The driver board for the 9.7" display is what they sent, but the connector is too small to insert the flex-wire connector from the 8" display. Arrrggghh! Just got off the phone with Digi-Key customer support and they now have to go check the other 15 in stock to see if this is a fluke or they have a bunch of non-matched driver boards. Guess I could get started printing the enclosure since that will take a while. :)
Lars Brinkhoff wrote 06/14/2021 at 06:18 point
Thanks for the information!
Lars Brinkhoff wrote 06/14/2021 at 06:28 point
By the way, I ordered mine from Mouser.  So maybe there's a mixup at Pimoroni.  I have emailed and tweeted them both.  (Sadly, customer service is sometimes better through Twitter than email.)
Lars Brinkhoff wrote 06/14/2021 at 11:30 point
Pimoroni is sending me new boards.
Michael Gardi wrote 06/14/2021 at 12:27 point
Great news on the new boards.
Michael Gardi wrote 06/13/2021 at 17:03 point
For sure that doesn’t look right.
