It doesn't seem to fit. The board layout seems slight different from other pictures I have seen. Maybe it's a mismatch?
A project log for VT100 simulator and 3D printed replica
Simulator for the VT100 hardware. Running inside Gardi's 3D model.
Someone over on Instructables had the exact same problem:
Sadly, the Pimoroni box from Digi-Key had the wrong display driver board inside. The driver board for the 9.7" display is what they sent, but the connector is too small to insert the flex-wire connector from the 8" display. Arrrggghh! Just got off the phone with Digi-Key customer support and they now have to go check the other 15 in stock to see if this is a fluke or they have a bunch of non-matched driver boards. Guess I could get started printing the enclosure since that will take a while. :)
Thanks for the information!
By the way, I ordered mine from Mouser. So maybe there's a mixup at Pimoroni. I have emailed and tweeted them both. (Sadly, customer service is sometimes better through Twitter than email.)
Pimoroni is sending me new boards.
Great news on the new boards.
For sure that doesn’t look right.
