1Required Components and Software
![Required Components Required Components]()
- Old Zapper Gun
- Raspberry Pi Pico with Soldered header
- Micro USB Cable
- Male to Female jumper Wire x5
- 330 Ohm Resistor
- LED x1
- Buzzer x1
- Screw Driver
- Soldering Iron
- Solder Wire
- Thonny IDE
2Unscrew the Zapper Gun using screw driver
![Unscrew Gun Unscrew Gun]()
3After Unscrewing open this Zapper Gun
![Open it after unscrewing Open it after unscrewing]()
4After open the Zapper Gun Now it will look something like this
![Opened zapper gun Opened zapper gun]()
5Required things from the zapper gun
From this zapper Gun here we need only
- a trigger push button,
- trigger clip with the zapper gun case.
For more clarification, you can refer to the images.
6Now take out the push button from the Gun.
![Take out push button Take out push button]()
7Solder the three, male to female jumper wire to the three pins of the push button.
![Soldering 1 Soldering 1]()
![Soldering 2 Soldering 2]()
![Soldered trigger Soldered trigger]()
8Solder Buzzer & LED
Now solder the buzzer, led, and resister with each other see the below image for the circuit diagram
![Soldered buzzer and led Soldered buzzer and led]()
![Soldered buzzer and led 2 Soldered buzzer and led 2]()
9Solder Jumper Wires
Now solder the one male to female jumper wire to the common anode pin of the buzzer and led and another male to female jumper wire to the common cathode pin of the buzzer and led.
![Jumper wire soldering Jumper wire soldering]()
10Microcontroller
Now for Controlling the T-Rex Game OR performing any other action, here, we are using the Pi Pico Microcontroller with the Soldered headers
![Pi Pico front side Pi Pico front side]()
![Pi pico back side Pi pico back side]()
Narayandojo Stemclub
