Hackaday Challenge 2017 Section
Challenge the project addresses- Dangerous protesters and rioters with masks destroying property and harming others, without the thought of any consequences through there anonymity.
How will alleviate or solve the problem that the project addresses?
- The theory of identifying a masked person in real time, reduces there chances of them causing a crime.
Discuss how the project might be world changing.
- Reduces crime, inspire someone else to build a better live facial recognition api.
In theory its simple.
Add a Pi Noir V2 IR with either 680nm, 720nm, 850nm, 950mm Filter to see through the black masked material.
Use Facial Recognition API,depending on the API use facial search matching, gather info which is shown on the prism.
Besides that it can be used for other things as well.
Publish at least one (1) image illustrating how the project might be used. This may be a sketch, schematic, flow chart, rendering, or other type of image.
Git hub link added
5/17/16
I'm assembling a low cost kit, also the prism will be a lot thinner, with the pcb instead of wires.
5/10/16 Im sold out of pre built prisms.
New Video of the Pi Prism Added new 16.5 x 38 DCX lens. With the Penta-prism the people facing you do not see the screen (mainly for privacy). Also I made the eyepiece bridge longer.
Blurry Picture taken with iphone (the screen is crispy clear irl)
OCR recognition demo above
older video of a Short demo of Pi Prism(with 14mm dia 20mm focal optics) with varying brightness sensor and prism.
Ricardo Ferro
julien
Leif Bloomquist
Arnov Sharma
spencer
Hello Ricardo
Thank you for putting in the effort. I am "reviving" this project for myself. I have small display that I am going to power with a LattePanda Alpha
Kind regards,
Martin aka PapaPimiento
