Spent a lot of time getting basic basically right, here is a demo using the C++ toolchain. This uses a set of vectors overlaid over a background bitmap with an animated sun moving across the background. The assets are loaded from SDCard after conversion by the GD2 asset converter.
The c++ code is on the merlin software github.
Cobra demo c++ code
