1getting the files.
go to my GitHub page and download all the files: https://github.com/George0023/pocket-nc-jog-controller
3D print the stl file in sequence.
2assembly
secure led, button and jog wheel so it look at the front of the controller.
wire up all component like this:
solder everything. -
3getting the software ready
the software instructions are over at GitHub, where you download all the files from.
4finishing
if the software run without problem, close up the case.
make sure the USB cable pass through the case's hole, and screw down these screw first; This should clamp down the cable and act like a strain relief.
screw down the rest of screws than you are done.
solder everything.
