For this week, most of my time was spent installing all of the various drivers/programs needed to run Arduino and ezDisplay on Windows.
Eventually, I got the files to compile and was able to upload the examples today (after a long and arduous battle with a defective programmer).
![](https://cdn.hackaday.io/images/8810011629236605249.jpg)
I was able to create my own image using the image2cpp site to display (mind the black line, as the screen is refreshing :') ).
I also looked into the functions and capabilities of the ezDisplay board, which weren't too many. Here is what I wrote down so far (it is still a very basic overview).
![](https://cdn.hackaday.io/images/7499061629236729894.jpg)
![](https://cdn.hackaday.io/images/1183191629236735544.jpg)
![](https://cdn.hackaday.io/images/1947361629236741171.jpg)
Excited to create the blocks!
It might be a good idea to add some hard-coded assets so that someone can see what blocks can do without going to the length to find an image, convert it, etc.... We can certainly add maybe 3 or 4 like a Barnabas logo or something to demonstrate.
Let's do it!
Additionally, I think it would be really cool if we could use conditionals/logic statements so that a student can input a string like "circle" and for instance "if circle == circle, draw 'circle'," which would be an image already converted as a default Circle.h file.
And also we could convert int to char in c-code for math operations to be done on ezdisplay board.
Sounds good to me!
also, in addition to the ezDisplay functions, there would be the blockly basic functions like delay() and loop() and logic blocks that the user can use.
