1Get Design Files
They're available on the project page.
2Order Boards
Send the files to your favourite PCB assembler.
3Recieve Anti-Static Burrito
4Unwrap Anti-Static Burrito
5Become Painfully Aware Of The Global Chip Shortage
For my initial prototypes I had to steal these memory ICs off of actual Adafruit ItsyBitsy M4 boards, at $20 a pop.
6The Ol' Switcheroo - *Whoops*
Apparently I put the SWD connector on backwards for my first batch of prototypes ¯\_(ツ)_/¯ we'll be flipping this around.
7Take A Moment To Enjoy What Went Right
Look at these lovely little gems.
8Do Hacker Things
9Verify Hackery Went According To Plan
10Breadboard, Meet Breadstick!
Now that the connector's flipped and the memory's soldered on, time to mount it to the breadboard.
I like to snap my header pins off using pliers, because doing this next task with flush-cutters would result in 20 mini-metal-missiles ricocheting around my lab, and that would be counterproductive.
We're going to need:
20 x 1 Pin
2 x 3 Pin
Insert them into the breadboard as such:
Now lay your Breadstick on top.
Notice we skipped the Reset and Aref pins? Only solder them if they're important to you. Otherwise they'll just take up valuable prototyping space.
I like to solder at either end before working inwards.
