Desk-ercising with the Exer-desk
Getting a little exercise during the daily grind.
A high desk and an exercise bike meet up in a home office to fight middle-age spread.
Like many folks, I've converted to working at home during the last year.  As a programmer, I don't need much in the way of equipment - a computer and a couple of monitors, and I'm good to go.
I have a small "office" in the attic of my house.  For most of the last year, I had a standard desk and office chair in there.  I worked in my little cubby hole just like I did in the normal office in the company building.
For the last month or so, I've been using this setup in place of a regular desk and office chair:
That's a very high desk with an exercise bike under it.
The idea sort of presented itself.
About a month ago, a friend of my wife returned a small "under desk exercise bike"  that we had loaned out.
That's this thing:
My wife used that thing as part of her therapy after having her knee replaced.
I used to be a really active person.  As a young man, I was 5 feet, 10 inches tall and weighed 120 pounds - the kind of bean pole who could change clothes behind a telephone pole.  I used to spend about two hours a day walking - not sports, but just getting from A to B to do things.  I walked to work, I walked to get lunch and go back to the office, I walked home ( the long way) in the evenings to take care of the grocery shopping (and pick up the occasional bag of kitty litter.)
When my wife and I moved to the small town we live in, the walking ceased.  I had to drive every where because nothing is close enough to walk.  I drove twenty miles to work.  I drove from the office to someplace to get lunch and go back to work.  I drove to the grocery store on the way home.
My weight has, naturally, gone up over the years.  If I stand sideways behind a telephone pole, you can see my front and my backside at the same time.
Working from home has actually made things worse.  I used to get at least the 5 minute walk from the parking lot to the office and back.  Now all I get is the climb up the stairs to my office in the attic.
I looked at that little exercise bike and thought "Ya know, it wouldn't bother anybody at all if I put that under my desk in my home office."
So I did it - and regretted it.
My desk didn't have much room under it and I kept bumping my knees.  My office chair kept rolling away from the exercise bike while I was trying to pedal.
The chair needed something to stop it from rolling away, and the desk needed to be higher or at least deeper.
I kept thinking it over and coming up with horrible, wobbly constructions that would be difficult and expensive to build and that probably wouldn't work very well.
I went to buy new tires for my real (and rarely used) bike one day last month.  The shop I went to happened to also sell exercise bikes.  I walked by one, and hopped on the seat on a whim.  It fit perfectly, and was surprisingly cheap.  I ordered one on the spot and had it delivered to my house.
The weekend after that, I went to one of the local building goods stores and bought a piece of kitchen counter top.  The stores often have small pieces left over after installing kitchens.  They sell those pieces pretty cheap.  I bought one that would be wide enough and deep enough to fit my computers and monitors for about 10 Euros.
I had a bunch of lumber in the garage that would serve as legs.  I bought some angle brackets and a bunch of screws to put it all together.
From the lumber and the countertop, I built a desk high enough for the new exercise bicycle (and my knees) to fit under.
Thus was born the "Exer-desk."
I spend about eight hours a day on the saddle of the exercise bike.  I don't pedal for all of those eight hours, but even just sitting still takes more effort than lounging around in a regular office chair.  I spend most of the time "half standing" - weight on one foot on the pedal with the other leg over the saddle so that it can rest.
I do spend some time during the day actively pedaling.  I try to pedal during...
  • On your bicycle, spaceman!
    Joseph Eoff • 07/18/2021 at 15:04 • 0 comments
    ... and measure the proper height for the desk.
    It took me a bit to figure out how high to make the desk.  I looked at my existing desks and office chairs and found that I usually have the height of the chair set so that the lowest point of my elbow is a couple of centimeters (about an inch) above the top of the desk.
    In combination with the exercise bicycle, the procedure looks like this:
    1. Adjust the exercise bicycle do that it is comfortable to "ride."
    2. Sit on the saddle, and sit straight up.  Back straight, proper posture for desk work.
    3. Bend your arm so that the lower arm is parallel to the floor.
    4. Measure the height from the floor to the lowest point of the elbow.
    5. Subtract four centimeters from that height.  Two centimeters is so that the desktop is a little below your elbow, and another two centimeters so that you will be on the "safe side" when you build the desk.  You can always raise the desk with the adjustable feet, but making it shorter means tearing it all apart.
    I measured about 115 centimeters from floor to elbow when seated on my exercise bike.  That works out to a desktop height of 113 centimeters. The desk top ended up at about 112 centimeters.  I guess I could raise it a bit, but it is comfortable enough as is.
    Calculate the length of the legs by subtracting the thickness of the desktop from the calculated desk height, then subtract the minimum height of the feet.
    In my case that should have been:
    • 115 cm elbow height - 2cm =
    • 113 cm desktop - 2 cm =
    • 111 cm desktop height with adjustment "slack"
    • 111 cm desktop - 4cm countertop thickness =
    • 107 cm bottom of the desktop - 4.5cm minimum foot height =
    • 102.5 cm leg length
    I ended up with legs 103.5 cm long.  I have no idea what I calculated wrong or which wrong value I might have used. I built the desk in the throes of an allergy attack - sneezing, cursing, and cutting wood by turns.  Anything is possible.
    At any rate, it worked out alright.
    At a regular desk in a regular office chair, the seat height is critical for me.  A change of as little as 5 mm can be the difference between a pleasant work day and a literal pain.
    It seems to be less critical with the "Exer-desk" - probably because I don't sit still long enough for any one set of back muscles to be over-strained.
    "On your bicycle, spaceman!" is a reference to A. Bertam Chandler's "John Grimes" novels and stories. The stories follow John Grimes from his graduation from a (space) naval academy from the Earth through his promotion to commander, and eventually being chased out of service and becoming the Admiral of the fleet for the Rimworlds - planets at the far edge of the galaxy, about as far from Earth as you can get.
    "On your bicycle, spaceman!" is used in one of the short stories (it is certainly in The Sleeping Beauty) from The Hard Way Up.  It is used as a parting line between spacers.  It is partially just an example of the jargon that develops between people in military service, and partially a reference (in universe) to the requirement for all ship crewmen to stay in shape by exercising  in the ship's gymnasium - which, naturally, includes exercise bicycles.
  • Thank you, Captain Obvious
    Joseph Eoff • 07/17/2021 at 22:30 • 0 comments
    A reminder of the deadline for the "Refresh Work-From-Home Life" challenge popped up on the Hackaday.com feed on Friday.  I hadn't really been aware of it.  I had looked at the "Rethink Displays" challenge, but couldn't come up with any ideas.
    The "Refresh Work-From-Home Life" thing just happened to mesh with something I'd done anyway.
    This is not the most involved or intricate project, but it fits the concept.
    This project is in truth rather simple, and it was rather crudely carried out.  I'm not a carpenter, I'm just a guy with some hand tools, time, and an idea (or two.)  It turns out that combination is enough to make some useful things.
    My "Exer-desk" is helping me get some exercise and improve my health.  Its useis only possible because of the peculiar set of conditions that have conspired to let (read: "forced") me (and many others) to work from home.
    I've decided to enter this project in the challenge.
    It isn't an Earth-shatteringly new idea.  It isn't especially clever.  It is just a combination of some existing things in useful way.
    Before I set out to write this up, I did a quick Google search and found that I could have bought a combined desk and exercise bike.  I could have saved myself the trouble, and just bought one.
    I didn't, and hadn't even thought to consider it when I set out to build my desk.  I made something for myself that somebody else happens to already produce and sell.  So it goes.
    I do hope that my project will give others ideas.  Maybe someone will manage to couple the exercise bike to a generator to charge a laptop battery (or provide power to the TV.)  Maybe someone else will make a nice looking "Exer-desk" instead of the industrial ugly one I came up with.
    Even if all it does is to encourage someone to buy and use a commercially made desk and exercise bike rig, that's still a win.  Any exercise is better than none.
  • Reinforcements have arrived
    Joseph Eoff • 07/17/2021 at 22:13 • 0 comments
    Originally, the legs were "merely" screwed to the counter top with the angle brackets.  There were 32 screws per leg.
    The brackets are rather short, though, and the the legs are rather long.
    The desk was all wibbly-wobbly (and not in a Doctor Who "timey-wimey" way.)
    It made me nervous to have the company owned monitors and computer parked on a desk that felt like it would collapse if I slipped off the saddle of the bike.
    I picked up some "not quite 1x2s" at the hardware store this morning and spent this afternoon making some braces to reinforce the legs.
    The desk now looks like this:
    Industrial ugly, but much more solid.
    I still might manage to fall off the saddle and pull the desk over on myself, but at least I don't have to worry about the desk collapsing if I push on it too hard.
    If you follow my blog, you might recognize the pictures on the monitors from some of my other projects.  On the left is a Wimshurst machine for generating high voltage.  In the middle is my D43 oscilloscope camera software.  On the right is an image made with my microwave camera.
  • Adjustable feet - overkill in hindsight
    Joseph Eoff • 07/17/2021 at 21:58 • 0 comments
    When I built the "Exer-desk", I had several things to juggle.
    • The desk needed to be high enough for the exercise bike to fit under.
    • The desk needed to be at the right height for me to comfortably type while sitting on the bike saddle.
    • The desk needed to be at the right height so that the monitors end up in a comfortable position.
    • The desk (and the bike) needed to be low enough for me to not bump my head on the (low) ceiling in my attic office.
    • The desk needed to be (somewhat) level despite any variation in length of the (hand cut) legs.
    Given all of those variables, I decided the only thing to do was to make the desk with adjustable feet.
    I measured things out and calculated what I thought would be the correct length, then made the feet with an adjustable range of just less than four inches (10 centimeters.)
    As it turned out, the legs are almost perfectly the same length and the lowest end of the adjustment is the perfect height.  If I'd have known I was that good, I could have just made them the right length and been done with it.  Oh, well.
    On the off chance that someone else may need to build adjustable feet for a desk or table, here's how I made mine.
    This was the goal:
    Adjustable feet, solidly attached to the legs of the desk.
    I started with some 8 millimeter nuts and bolts and a bunch of steel plates:
    That's a rod of silver solder there in the picture above the steel plate.  Some people weld, others braze.  I silver solder.
    I drilled 8.5 millimeter holes in the center of all the plates.  The short screw and nut are used to hold the other nut in place while I'm soldering.
    Like this:
    It looks like this when I'm soldering things together:
    The torch is lying there on the other workbench while one of the steel plates with a soldered nut is clamped in the vice.
    I bought four rubber feet.  I had some long 8 mm screws and a bunch of nuts and washers in the garage.  A bolt, a washer, a nut, and one rubber foot go together like this:
    The big flat screw heads and the washer keep the bolt from tearing out of the (relatively) soft rubber.  The nut holds it all together.
    The nut soldered to the plates hold the feet.
    When I put them all together, I put in an extra nut to lock the adjusting nut.
    The long 8 mm screws go into 9mm holes I drilled into the legs.  The plates are screwed to the legs to keep things together.
    Unlock the lock nut and screw out the foot to adjust the height,  Tighten the lock nut when done.
    The screws I used were something over 100 mm (4 inches) long.  You can use most of that adjustment range with these feet.
  • Gathering the Materials
    Joseph Eoff • 07/17/2021 at 21:33 • 0 comments
    I am often accused of buying stuff for my projects rather than using what I've got.
    I do try to use what I have, but sometimes the things you need aren't the things you have.
    In this case, there was a bit of both.  I had some things I could use, and had to buy some other things.
    These are the things I collected to build the "Exer-desk":
    There's a piece of kitchen counter top there supporting the other bits and pieces.
    There's several "not 2x4s" that I had in the garage - left overs from previous projects.  They are "not 2x4s" because I'm in Germany.  Those pieces of lumber are a bit thicker and wider than the 2x4s I grew up with as an American kid.  They are some metric size - I neither know nor care what size.  I use 'em like 2x4s, and they do the job.  I made the desk legs from them.
    There's two packages of screws there.  150 screws, to be exact.  I used danged near all of them.  That's one of those "you have to have the right part" things.  They have to have the right diameter to hold well in the pressed wood chip counter top, and they need to be long enough but not so long as to come out the top of the counter top when you put them in from the bottom.  I have loads of screws in the garage - and none them the correct size or length.
    There's a stack of 16 angle brackets.  I used them to attach the legs to the counter top.  I had a few brackets, but no where near enough for this job so I bought a whole bunch of identical ones.
    There are four rubber feet in there as well.  There's a (rather long) story to how those fit in that I'll explain in another log.
    I bought a switched outlet strip to install under the desk.  I like to turn things OFF when I'm not using them.  That outlet strip is one of the rare ones that has the cord and the switch at different ends.  The cord goes out the back way, and the switch is up front under the desktop where I can easily reach it.
    There's a roll of iron-on edging for the counter top to cover the rough edges where it was cut.  It looks like a roll of duct-tape.  I haven't put it on the desk yet.  I suppose I really ought to - it cost near as much as the counter top itself did.
    I only bought what I had to, but this time around that turned out to be everything but the legs.
View all 5 project logs
z26 wrote 11/27/2023 at 10:38 • point
Hi,
I've also wanted to do this since a long time (with a more comfortable recumbent-style seat) , so this page is a nice excuse to brainstorm about it.
After 2 years, you've commented on your project that "I find that I don’t pedal all that much.", which makes me wonder about the psychology of such a setup. Someone suggested to make your monitor turn off if you don't pedal enough.
For some stuff I do, I need my full concentration and can't pedal all the time. Instead, a revolution counter could use up stored revolutions at a given rate, so that I can "store up" revolutions during more idle activities then stop pedaling during more involved work.
Shutting off the monitor is also quite drastic, since it renders the computer completely unusable. I need to find a punishment that is annoying enough to be good motivator, but tolerable enough to be endured in emergencies. I don't ever want to reach the point of turning off the device because I'm too busy with work, because I'll start using weaker and weaker justifications to do so as time passes on.
While low intensity exercise may be best for pure weight loss, I'd also like to get fitter. Exhaustion scales non-linearly with intensity of exercise. (pedaling one hour at 200 watts is a lot more work than doing so for two hours at 100 watts) As such, I'd like to add an extra bonus that multiplies your revolutions when you pedal faster.
Thanks for getting me to think about this project again.
dearuserhron wrote 07/20/2021 at 19:25 • point
Ha ha, I have seen it so many times in movies. Zero Theorem (Terry Gilliam).
And Black Mirror, of course.
