• Assembly instruction video
    Wim Van Gool • 08/04/2021 at 10:27 • 0 comments
  • Battery switch
    Wim Van Gool • 07/27/2021 at 08:53 • 0 comments
    By popular demand, a new revision of the kit was created with a SMD switch added. This slightly increases the price, but if price is important a simple solder bridge can be made as well to bypass the switch. The SMD switch has small plastic pins in the PCB allowing for easier placement and soldering.
