Assembly instruction video
08/04/2021 at 10:27 • 0 comments -
Battery switch
07/27/2021 at 08:53 • 0 commentsBy popular demand, a new revision of the kit was created with a SMD switch added. This slightly increases the price, but if price is important a simple solder bridge can be made as well to bypass the switch. The SMD switch has small plastic pins in the PCB allowing for easier placement and soldering.
